-   LD9 2.4L Twin Cam Specific (http://www.aleromod.com/forums/forumdisplay.php?f=20)
-   -   motor blew (http://www.aleromod.com/forums/showthread.php?t=29139)
[ion] C2 10-19-2009 11:26 AM
What the hell? Someone deleted my post. Seriously what the f*** administrators?
I asked the guy if he was able to turn the crankshaft by hand, it's a 1 1/16" wrench. I asked if the engine blew up or stopped running while he was driving it or if it was something he just noticed one day when he went to go start it, because maybe it's just the starter. He hasn't really given any specifics on what happened so we don't know what's up.
zzyzzx 10-19-2009 02:47 PM
Originally Posted by colonel6632 (Post 502325)
yup. thats what the paper work shows. that includes new block and everything
Can you post the info from the reciept?
I had a Japser engine put in my Escort once, and it cost $3950, and I thought that was expensive.
zzyzzx 10-19-2009 02:48 PM
Originally Posted by Alerojester (Post 502236)
boosting the 2.4 was my other idea, i have found another motor for $500 with 94k miles on it which is 400 miles less than mine has... I mean boosting it would be fun it would be the only one where i live.
Originally Posted by Nate's Alero (Post 502249)
you must beat the living piss out of it...... 101K miles!?!
Hmmmm 94,000 + 400 = 94,400, not 101,000
[ion] C2 10-19-2009 03:35 PM
Originally Posted by worknprog.99 (Post 502324)
an engine replacement costed 7k ??
haha x2
my built engine only cost about $2100 ($1300 parts, $800 build)
twagn 10-19-2009 03:48 PM
Originally Posted by colonel6632 (Post 502291)
paid 7k for the car
Ouch:cry:
colonel6632 10-19-2009 07:59 PM
i'll scan it up for you guys sometime soon
- edit -
heres the picts sorry they are a little big. you may want to download them and then use a zoom tool on windows or something. but they are huge. and i lied. it was only $6800
AndyT3 11-24-2009 11:58 AM
Wow, still seems like a lot for an engine, but oh well...
jayson_waltz 11-24-2009 12:08 PM
^not really for a brand new gm crate engine. and its CAD remember, its always more expensive up there.
AndyT3 11-24-2009 12:33 PM
Yeah, thats true. Didn't think about the geographic difference...
Alerojester 11-24-2009 12:41 PM
Ok so we started tearing into the engine and its just the crank bearings, good news is that I can get the bearings and crank for about $150.00 then i am going to replace sensors as I go first one is the oil sensor that will be done when i replace the bearings and crank.
Little side note wondering how to get an aleromod.com Vinyl for the front window???
Nate's Alero 11-24-2009 02:04 PM
i had mine made custom, think cafepress makes them though, google it
Raziel 11-24-2009 04:10 PM
- edit -
WE KNOW WHERE YOU LIVE:eek: lol jokes....Of coarse it's expensive that's Saskatoon Motor Products for ya and of coarse the dollar difference too between countries. I would just go to a wrecker and find an engine for it, it would be cheaper in the long run instead of puttin in that 3.8 but that's my opinion.
Raz
Alerojester 12-03-2009 03:32 PM
Ok new question on the whole thing i can get a 2.3 block but no head is there anyway that if i put my head off my 2.4 on it would it work??????? or should i just get over the price for the crank kit and buy it????????
IRONDOG442 12-03-2009 04:49 PM
Originally Posted by twagn (Post 502234)
3.5 dual cam Intrigue motor would be cool if it fit
this man speaks troof!
spyhunter 12-03-2009 07:11 PM
stay 2.4L w/ 2.4L and 2.3L w/ 2.3L.....
spyhunter 12-03-2009 07:12 PM
That oil light sensor in the head is a dummy light. If that light goes on and says Low Oil, you're already too late. A better rule of thumb EVERYBODY should do regardless of make/year/etc... is at every gas up, check the fluids, belts, battery connections, clean the windows, and check tire pressures.
A57 12-06-2009 12:38 PM
Just some info for you,
the 2.4 is the replacement to the 2.3L the 2.3 fail in the head crack alot and head gasket would fail alot to....
So the GM engine builders re-did the 2.3 and came up with 2.4L
I agree to stick with 2.3 to 2.3 ect...
Now if you can find a w41 block now that was a racing beast ..
I remember this site had all that was mantapart....
http://www.mantapart.com/
good luck on your build.:cool:
colonel6632 12-06-2009 02:46 PM
Raz
thats ok, i've moved
Nate's Alero 12-06-2009 02:49 PM
i doubt anyone on here will come up and kill you.... i've met a lot of guys on here....no one insane.... (annoying, but not insane)
spyhunter 12-07-2009 01:19 PM
mantapart has a lot of stuff, but they're highly UNreputable in service.
The new batch of 2.3L headgaskets that are now on the market, get rid of the issue of headgasket failures.
If someone wanted to build a sweet motor they don't need a 2.3L block, even if it was a w41 block. W41 block is the same as any other 2.3L block of its year. The head isn't any different than a 2.3LHO. The goodies that a person would want from a w41 is the rare red IDI valve cover and the cams. The intake manifold is the same as a 2.3HO, blah blah blah.
