-   -   update (http://www.aleromod.com/forums/showthread.php?t=29381)
[ion] C2 11-13-2009 12:19 AM
The SU1477 is the right one, it's just expensive. The cheaper one looks like this and is totally the wrong connector:
Cliff8928 11-13-2009 12:23 AM
I do believe that's the one that would work on the 3400.
[ion] C2 11-13-2009 12:24 AM
Edited: wrong part again. Confirmed not a working MAP sensor for the application.
2fst4u 11-13-2009 10:16 AM
so what is the cheapest map sensor that's 2 bar? i need it today. help me out
Nate's Alero 11-13-2009 10:28 AM
that was the 3400 MAP, should be able to get a new one at autozone, i dont think you have much of a choice, but to buy that expensive one
[ion] C2 11-13-2009 10:35 AM
i'm trying to find it. there is a $45-60 one. Fi-Alero has it but won't look at the part number on it. he says it's one of the ones i told him to get. i'm looking through my PMs.
2fst4u 11-13-2009 10:39 AM
will it work on the 2.4?
[ion] C2 11-13-2009 10:40 AM
the two $160 ones i listed are the exact part but there is an alternate part number that's the same thing that is $100 cheaper.
2fst4u 11-13-2009 11:14 AM
if you can find it, that would be amazing. funds are tight, just want my car back
[ion] C2 11-13-2009 11:17 AM
SU1078
AutoZone
About $47. Just need to take off the orange rubber seal and stick on your boost/vacuum hose.
2fst4u 11-13-2009 11:50 AM
hero of the day
2fst4u 11-15-2009 12:17 AM
alright, so the map sensor is in. but, the car is still running extremely rich. i'm not sure why. at this point, i've contacted the guy that tuned my computer, but i'm not sure if he's going to get back to me.....dissappointing
2fst4u 11-15-2009 12:24 AM
2 Attachment(s)
some new pics
[ion] C2 11-15-2009 06:03 AM
You're not on just the GM Reflash?
2fst4u 11-15-2009 09:49 AM
no, i'm running a tune from shifted over on j-bodies. any chance you could look it over? i'd send you the computer and make it worth it for you
[ion] C2 11-15-2009 10:00 AM
I just need the .hpt file
2fst4u 11-15-2009 01:04 PM
i'll see what i can do. no response from Ron yet.
2fst4u 11-17-2009 11:48 PM
so, the report from the mechanic says that, the computer is reading 40 degrees below zero and 100 percent load when first started.....any ideas?
[ion] C2 11-17-2009 11:53 PM
-40 IAT means it's unplugged. Same with coolant and all other temp sensors I think. Sometimes when I hit "Start Scanning" on HPTuners one of the temp gauges will be pegged at -40. Just need to stop and start the datalogging again and it fixes it. If it's solidly -40 no matter what it's obviously an issue with the sensor.
What do you mean "100 percent load"?
