are you serious?? :wtf: |
So...ummm...how is NOS any less ricey than a dry-ice cooled intake? I've never seen Vin Diesel hit a dry ice button and go into warp drive, and I've never heard of anyone blowing up an engine because they put ice on their intake (as said above, this is a trick that has been around for a long time, usually used at the drag strip between runs or on the dyno). Frankly, it's a good idea, but I assume that the air would pass through too quickly to really make m,uch of a difference, which is probably exactly why CryO2 put a bulb in the intake instead of just surrounding the tube with lines or something. I think people are way too quick to judge things now, but looking at a small, harmless, bolt-on "mod" like one of these things and saying "Just git nawws" is twice as retarded as this guy's "rice box intake."
are you serious?? :wtf: [/b][/quote] yeah, but for some reason I can't find the pics. It's actually not a horrible IDEA, just the implementation of the idea was quite ghetto. lol |
I'm not imagining it: someone else seen it too.
http://forums.stangnet.com/showthread.php?t=417698 |
Thats Dumb....Im not even close to knowing alot about cars..but I do know simple math and chemistry.
The Ice around the tube would cool only a portion of the tube...and not fast enough to cool any air down enough to make a difference...The air is moving so quickly that itd have to be cooled instantly at a certain point right before being heated again going into the the cylinder where its 50 times hotter than it was colder in that tube...doesnt make any sense...justa show item I think I mean if you look at the intake systems first picture...its condenstaed only like 6 inches past the actual ice box...thats where the cooling ends...and starts to heat again as its put through two strokes of the engine in the cylinder(Intake, Compression...its put through those at the same time the engine has just got down Blowing up a gas air mixture in the same cylinder so I Imgaine its hot) giving it plenty of time to warm back to where it was originally and even hotter before the combustion stroke.... which goes Boom lol |
well, it does look like dry ice rather than real ice, which is quite a difference considering ice is frozen water and dry ice is compressed CO2 gas, also, dry ice has a surface temperature of -109 degrees F, or -78.5 deg. C .............so i dont know, i think implemented in the right way, over a majority of the intake it could cool the air somewhat.........i'd like to see someone build an intake that flowed straight liquid nitrogen through the walls, considering the boiling point of liquid nitrogen is at - 309 deg. F
dump some liquid nitrogen in there. j/k
The only thing I can think of that would do something to this effect we are trying to reach would be some type of Very very cold gas that is also flammable...so that once in the cylinder it burns off well
I dunno how effective it is exactly, but water injection is good way to cool compbustion temps. It's atomized so it cool temps quickly and will not cause hydrolock. They use it a lot on forced induction engines where intercoolers aren't practical/feasible, or just as an extra bit of cooling after the intercooler.
I think I'd rather repeatedly smash my head into a wall than read through some of the threads on that forum again.
OF COURSE!!! Why waste all that money on a supercharger when i can just hook up my craftsman leafblower to my intake for free! ill be running 14's in no time!
alero_ecotec hit it... it's definately dry ice... i was gonna say that till i kept reading down and he already covered it.... there is no possible way normal ice would be cold enough to frost the pipe past the box... and if it were normal ice you'd have to drain the box... the dry ice just evaporates... at first i didn't notice that the ice was around the pipe... i thought the air just went on the ice... i was like... yeah great plan... suck a c02 rich mixture in... that'll work great. they should think up a limited spray liquid oxygen injection for intakes... it's be super cool and oxygen rich... that'd be the poop
i wouldn't be suprised if it had led's on the inside of that ice box to to complete the "fast and the furious" look
