I don't post here often, but I check the boards every now and then. Reading this makes me think I should put my Alero up forsale, and I'm being serious.
2001 3.4 w/ 46k miles 22k miles--- hazard switch replaced under warranty 23k miles--- driver window needed new motor, replaced under warranty 30k miles--- front pads and rotors warped, replaced under warranty 40k miles--- front rotors are warped again, still haven't done anything about it 42k miles--- low coolant light came on. Wife stopped by the dealer and the dealer topped it off, but after reading here it sounds like I might have the infamous gasket leak you guys are talking about. :angry: 45k miles--- SES light is on, autzone scanner says "P0442 Evap Emissions Control Leak". It's not the gas cap and I haven't had time to look any further into it. I bought this car only because I got what I thought was a terrific deal. I bought it in December of '02 w/ 18k miles on it for $10,500, which I guess still isn't a bad deal, but if I'm going to have all these problems I'm not certain I want to hang on to it especially seeing as though I no longer have a warranty. |
Ok lets see......bought in july of 2003 or so with 63,000 miles
72,000 snapped the turning signal handal(my fault) still works but need to fix soon 74,000 miles gasket leak 75,000 gasket leak fixed (lol) 76,000 accident, body repaired 76,500 passenger side window regulator breaks 78,000 winshield wiper pump starts leaking no problems with rotors, or pads, the pads need to be changed soon, and ill probably have the rotors turned...... |
i bought my 2000 v6 last may with 38,000m on it. the only real problem i had so far was replacing the left outer tie rod at 49,000m. the brake pads and rotors do need replaced though. they are still the stock ones. the guy at the shop said he could turn the rotors but then they would be too thin to meet specs which tells me that they have been turned a couple times already. after market here i come. oh and recently when i drive the car for the first time each time or after it sitting for a while i hear a slight screech coming the left front wheel, i think its just my brake sensor telling me "i need replaced", any other ideas? i currently have like 51,000m on it.
Check this site out |
99' 2.4
108,000 (ouch) I have had the car for a couple months and nothing so far, thank god. Dont know what was done to it before i got it except for new bumpers and fenders. |
'02 3.4L V6 (96432mi)
Bought it at 90k 92000 - Engine teardown, lifters were clogged, replaced lifters. 93400 - Hazard Light Switch (Non-Recall, bastards!) 93600 - Window regulator replaced, window replaced 93900 - window regulatior replaced 93900 - battery/alt replaced 94000 - Cat Converter 95000 - Accident, minor cosmetic shit, not fixed yet 96000 - electrical demon. |
2002 3400
Bought it with 34,000 (Last July) Now has 49,200 Problems: NONE I have had NO problems at all, i dont know why everyone has major problems!!lol I actually had one problem and that was one of the bolts were loose and it caused a leak, but it was tightened and stopped. |
01' 2.4L 68000km
Bought with 28000km, last summer(05), came with new rotor and pads. 29000 Fan control resister blew haven't bothered changing yet 57000 Replaced Frt passanger Hub and Frt drivers tie rod 65000 Bad millage, used seafoam problem went away 68000 Bad millage returned (don't know why) soft brake pedal (just dissapeared 2 days ago??) All in all she's treated me good (knock on wood). |
Purchased in March 2004 with 50K now in November 2006 92K
Problems: 50K- Lower intake gasket/water pump 50K- Stearing rack 50K- Trunk vent Leak 50K- Swaybar links and Bushings 64K- New hood, Crossmember, headlights, AC compressor, many other parts replaced after accident. 77K- Front wheel berrings, both sides 83K- Water pump again and serpentene belt 92K- Curently AC line still has leak after accident, Gas gauge messed up, Needs power stearing pump, and new AC compresser berrings. |
my turn,
2000 GLS 3.4 V6 40,000 km head gasket 90,000 km LIM #1 180,000 km wheel hub 190,00 km LIM #2, power steering gear and shaft seal, A/c clutch, blower motor resistor(don't know for sure when that went, it was before I owned the car) water pump, right front break caliper, strut mounts...i think thats all |
2000 2.4L w/169,000 mi
Got it used at 167,000, needed rotors. At 168,000, A/C compressor clutch went. Always had the hazard switch issue (not under recall they say... o_O) Other than that, running and performing to perfection. |
99' v6 86,000 bought car in 2001 had 35,000 when i bought it.
I cant remember exact mileage but here it goes gasket leak (warranty) alternator died (husband fixed) left front hub right front hub brake pads gone bad( husband replaced both pads and rotors) rotors grinding driver side window would get stuck (my husband fixed) driver side tie rod replaced serpentine belt worn out (husband fixed) replacement of battery water pump leak |
Mybe, I got lucky purchase with 9,xxx miles
@ 36,xxx switched to stop tech brakes (front) @ 54,xxx battery @ 87,xxx IAC Valve @ 110,xxx got rear ended 11 months so far and still sitting in the gargage |
lets seee..... got it at 75,000 miles
at about 80000 i had to get a new fuel pressure regulator now at 86000 im gonna need some new rotors and brake pads soon i changed spark plugs.... put in NGK iridiums 84000 new battery other than that this car has been mildly reliable, but my gas is starting to suck..... i put 89 bp silver in religiously |
1999 2.4L GL
Bought: 34,000 miles Now?: 99,900 miles "major" repairs: -drivers side window motor went out -something to do with the spark plugs once.. this insane misfire thing that literally came out of the blue.. and left me stranded.. right after i pulled into my driveway! =D -that gasket leak thing thats such a problem.. -new brakes installed once.. o.O" -alternator died..hahaha i remember that! And other than my wrecking the living crap out of it and getting that fixed.. thats all. My baby boy hasnt been that bad to me. not for about 100k miles. i work him to death =/ |
2003 GLS 3.4 V6
Bought it 2 yrs ago w/: 17,xxxmiles now has: 46,xxxmiles Only thing that needed work: - new rotors and brake pads |
2000 GLS Coupe 3400
Bought new with 249 miles, now 66,000. 12,000 Front half of the car was repainted due to some brat pretending to be Bo Duke and scratched the hell out of the hood and fender. $500 bill!!! 12,001 Killed brat, washed blood off hands :) LOL 15,000 Old dude backed into my car and front end was painted again!! His insurance covered. 34,000 Hazard light switch, Blower motor resistor (warranty) 44,000 LIM, fixed itself!?! Not questioning it, not leaking any more. No coolant in oil, external leak. Have the gaskets just in case. 65,000 Driver side power window rear clip, Cyl #1 misfire due to bad plug wire. 65,000 3rd brake light lens warped. Otherwise basic maintenance, brake pads, oil changes, spark plugs, filters etc. |
2000 GLS Coupe
Bought in Feb. with 60,000miles, now 74,000 miles In the first month Both wheel speed sensors Hazard Switch x2 Power Steering Pump Window fell off track into door and broke Cruise Control Switch Later Brake Job Sunroof Leaked into fusebox Lights on gear select on the dash are all screwed up, says 3rd when its in Neutral Sometimes the sunroof will open a few inches, other times it opens all the way Dash is rippling up Last Monday an old lady pulled out in front of me and caused $4k of damage, still don't have car back Everything in the first month we made the dealer pay for under some sort of law we have in KY. Suprised I haven't had the LIM leak yet. |
10/09/2006 - 26,506
ENGINE, UNIVERSAL - REPLACE, REGULATOR, FRONT DOOR WINDOW - LEFT POWER - R&R OR REPLACE, MOLDING, WINDSHIELD SIDE PILLAR REVEAL - RIGHT - R&R OR RE, DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE, MOTOR ASSEMBLY, STARTER - REPLACE, Spark Plug Replacement, Engine Cooling System Service, GM Oil Life System Maintenance. 07/06/2006 - 21,445 GM Oil Life System Maintenance. 04/29/2006 - 17,308 Install new larger front brakes.. Notes: Installed F-Body rotors, pads and caliper brackets. Installed Y-Body calipers. Installed 17" wheels with new tires. 01/17/2006 - 13,839 GM Oil Life System Maintenance. 06/21/2005 - 8,100 Engine Air Cleaner Filter Replacement, Install K&N. 05/24/2005 - 6,410 GM Oil Life System Maintenance. 02/14/2005 - 3,921 CONTROL ASSEMBLY HVAC (INSTRUMENT PANEL) - A/C - REPLACE, ADJUSTER ASSEMBLY, FRONT SEAT MANUAL - BUCKET SEAT - DRIVE, CLUTCH SYSTEM, HYDRAULIC - BLEED |
