installed an HID kit for fisdad. FINALLY upgraded!!!
Nice. I want to do that to mine too. Someday..
its cheap and easy
Swapped in the Intrigue instrument cluster.
![]() Thanks to user Difflay for instructions to swap circuit boards to make it function. |
any chance on a how to?? :) I heard there are some wiring issues to contend with...
Difflay posted that the circuit boards need to be swapped. So, buy an Intrigue cluster (I bought a reman one off fleabay). Take the black plastic cover off the back of the Intrigue cluster. Carefully remove the printed circuit board - it's just a friction fit. Do NOT touch any of the circuits or solder points! Disconnect your battery. Remove the cluster from your Alero and remove the printed circuit board with the same procedure. Install the circuit board from your Alero into the Intrigue gauges, being careful to line everything up before pressing together. Pay special attention to the PRND321 lights as they are on a separate daughter board. Reassemble and install the new cluster into your Alero. Reconnect your battery and test it out! |
nice matt
Why'd you install the HID for fis? A 10 year old could do it lol
cause i was there at the time, and he was a little confused.
Was it really that hard for him? Or was the kit screwy? I know my kit from DDM tuning was weird because of the way they ship them out (they attach a random wiring harness to the bulb, but tell you to clip it. I ended up using it as an extension instead)
well hes got the euro headlights and last he checked the how to on here (been awhile) he thought it was splicing. the euro heads arent regular 9006 bulbs they changed to H7 so it was new to me but got it figured out after a min. but i told him it should be plug and play, etc.
its always nice to help someone out, im sure he could tackle it, but why not help when hes got it laying there and wanting it installed? lol |
Who da fk still helps people in the world? lol
Sleepy does because he's not about that Yolo bull shit.
if you give, you sha'll receive, my brother.
I do alot of giving. The receiving is non-existent.
maybe cause your a pr!ck. ;)
Exactly...I go out of my way to help anyone who needs it and I have absolutely no trouble finding help whenever I need it...but I live in a small town where people aren't hippies or aholes.
I thought that the old how to said I had to cut and splice and run a harness? It has been years since I looked at a how to. I didn't realize that they were just plug and play. I was doing like 5 projects to my car that afternoon also so it was nice to have an extra set of hands to speed it up. |
you're welcome.
I miss DrFab and his HID rants.
