I have a low tire pressure light on. I filled the tires to the tire pressure the door say they are to be at and the light is still on. Do I have to reset it or should it go out by itself? If I have to reset it , how do I? Thanks
reset button in the fuse panel on driver side turn key to on position with out car running push or hold (every car is different) the reset button till change oil or tire pressure light is blinking then hold the resetbutton in turn off then on the car should be reset
we really need a how-to for ppl to read when it comes to the oil and tire light comming on and how to reset it, this is a common trend im seeing that can be easily be avioded if ppl used the SEARCH function
Thanks for letting me know! :thumb:
Or the owners manuel...... |
:glare: well at lest his works, mine has nevers come on, and i always get flat tires
Dont worry about it, they dont work when they do work lol
Owell, i got better tires anyway, i hope they dont blowup. :hide:
only some Alero's have low tire pressure lights. Your Alero probably doesnt have one lanzt.
Well it should, with my luck with tires :punch:
