-   -   Rear Springs Rattling (http://www.aleromod.com/forums/showthread.php?t=12545)
Lovestheh20 04-28-2006 12:37 AM
alright, so I just got some sping tech's installed a couple days ago w/brand new monroe sensatracs. and I have this rattle coming from the right rear wheel well.. it sounds like something is loose?
the rears are fully aligned, caster, toe, and camber.
the guy who installed it said I have to be careful when I jack the car up because the springs don't stay tight like the fronts do, and can slide out of position. anyways, the car hasnt been jacked up at all since the install.
anyone else here have springtechs and can chime in?
2fst4u 04-28-2006 12:41 AM
yeah, constant problem. just wait for the pop sounds from the front end. eag182 was whining about this the other day. lol
btw, nice front struts.
Lovestheh20 04-28-2006 12:42 AM
the fronts worked out like a charm bro. :)
its the rears that are giving me problems! I can't stand these crap WI city streets.
UnoWHO 04-28-2006 06:54 AM
The fronts will squeak when it gets rainy, or humid, it sucks lol
eag182 04-28-2006 11:00 AM
fronts shouldn't. rear right should LOL. Yea, 2fst4u, it gets annoying. It will only happen when lateral stress is put on the tire, i.e. TURNING.
Lovestheh20 04-28-2006 04:19 PM
eag - do your rears sound like something is loose?
sofa 04-28-2006 04:22 PM
my rears squeek after installing my springs sounds like its coming from the middle wishbone lubed it still same thing.
eag182 04-28-2006 04:54 PM
sounds like a croaking noise
nothing sounds loose
Lovestheh20 04-28-2006 05:17 PM
oh no, I get a definate rattle like there is a bolt loose or something.
eag182 04-29-2006 04:13 PM
so tighten it
alerotuner99 04-30-2006 08:23 PM
i have the same problem on my alero. I put intrax springs on sensatrac struts and i have the same rattle in the rear. I did all the work myself too installing the springs and struts and doin the alignment since i work at a dealership. It seems to me they rattle because my rear springs don't have the rubber insulators on the bottom of the springs like the fronts do. i'm not sure if u could put some kind of rubber insulator underneath the spring to fix the problem.
ptrudel 05-01-2006 03:33 PM
man i've had mine on for over 2 years and they dont make noise at all...except the front recently from bein jacked and put down about 10 times..but once i start driving, it'll get back into place and stop...i dunno why you guys are havin problems
Lovestheh20 05-02-2006 01:49 PM
alright, well I finally tried getting the bolt on top of the strut mount tightened.. didn't do anything. The sound is coming from the washer underneath that bolt. does this setup need spacers or something? I thought the only struts that needed those were KYB's
steve-o 05-02-2006 02:01 PM
dont know what to tell you dude, i got ST and kybs on my car now and have no problems with anything like that. i did use all the rubbers and stuff when i did the install, no metal on metal.
alerotuner99 05-02-2006 06:02 PM
so is there supposed to be rubbers underneath the springs in the rear cause mine didn't have any when i took it apart. I did notice my swaybar bushings in the rear are pretty worn and could be making most of the noise.
steve-o 05-03-2006 09:15 AM
there was a little plastic piece, the bushing might be an issues too, now that its dropped, more stress on the bushing that might be already on there way out.
kaularo88 05-16-2006 11:49 AM
have you checked the strut mounts? thats what was making the loose bolt sound in my car. :)
