-   -   Big Problem (http://www.aleromod.com/forums/showthread.php?t=12602)
Menace 05-01-2006 02:17 PM
When I drive I heard a loud constant squeeking noise on my front driver side wheel. I re tightened the lugs and it still made the noise then I washed out the wheel with my hose ( thoguth maybe somthing got caught in there). Well the noise stopped for about 5 minutes then it started again. Does anyone know whats going on ? Maybe my wheels arent getting any brake fluid because I havent filled it up a long time and its still full to the line. If so how do you bleed them ?
battistoni21 05-01-2006 02:26 PM
possibly your hub? Just a suggestion, im not sure.....
Redog 05-01-2006 02:48 PM
need brakes?
Menace 05-01-2006 03:34 PM
I put on new brake pads and rotors like 1000-3000 miles ago
Menace 05-01-2006 05:03 PM
I bled the brakes which was easy as hell if anyone needs to know how to do it just ask me ill help yah out. It worked fine for like 30 mins then started to squeek again maybe after 30 mins air got pushed down into the hosing again.
brsexton 05-01-2006 05:39 PM
What kind of brake pads did you use? It may be the metal in the pads doing it. I had this happen with the pads on my old car. You should take the pads off and run some sand paper over them.
alerotuner99 05-01-2006 06:14 PM
make sure the metal slides where the pads sit at aren't touching your rotors. My car was making a screeching noise a week ago and the slide was touching my one rotor so i bent the slide out of the way and no more noise. It also could be your wheel bearing goin bad but i'd check the easy stuff first.
Menace 05-01-2006 08:31 PM
I use bendix ceramic pads, I havent heard the squeeking noise for a while I think the brake bleeding worked.
alerored04 05-01-2006 08:34 PM
I have the exact same pads and i hear no squeaking, bleeding it probably helped a lot.
zzyzzx 06-20-2008 09:38 AM
OK, how do you bleed brakes on this car? I've never done it on a car with ABS. I've done it on a non-ABS car lots of times.
[ion] C2 06-20-2008 09:41 AM
1 Attachment(s)
bad lol
surreal_awakening 06-20-2008 09:46 AM
Thanks for the Madden-like illustration, ion LOL
cliffordwoeller 06-20-2008 10:18 AM
lol thats funny another one comes back from the dead
cherrington17 06-20-2008 10:23 AM
you'll probably want to ask that question... to a member WHO IS STILL ON SITE!
adam337 06-20-2008 11:27 AM
Diieee Zombieeee
Vinalero 06-20-2008 11:38 AM
Actually, that proves he used the search button. Isnt it what everyone ask to do before starting another tread?
[ion] C2 06-20-2008 11:46 AM
ya but his question is a new issue unrelated to this thread, should've just posted a new thread
but anyways you just loosen the bleeder screw and uh, bleed em. nothing special as far as i've seen.
Alerosaint 06-20-2008 11:57 AM
Originally Posted by adam337 (Post 366205)
Diieee Zombieeee
lol....you stay kiling zombies...straight out of Resident Evil huh?
