well my wifes 03 alero has had is SVS ABS and Traction lights on for quite a while now, hasnt really hurt the performance havent noticed anythign at all, not sure if the ABS are really not active. process of elimination lead me to believe its the wheel speed sensor. where can i purchase them, how many do i need and how hard is it to replace said item?
thanks for any help in this matter im clueless when it comes to alero's thanks again ryan :alcoholic: |
well doing research i found that its part of the wheel hub assembly, we had both fronts replaced under warranty last year about 9,000 miles ago, called the shop they will cover it if it is the wheel hub, so oh well here we go again :gun:
its prolly ur hub, my lights were on for about 2 monthes, then my dad borrowed a nice scanner and found out the pass front wheel sensor was bad. it set me back about 110 bucks
