-   -   Batteries (http://www.aleromod.com/forums/showthread.php?t=12854)
white04alero 05-16-2006 12:27 AM
ok.. i went to lowcostbatteries.com and looked up an optima battery.. they say none fit my car.. wtf.. are there car batteries that wont fit certain cars? i thought that as long as they were car batteries.. puttin out 12V it was fine.. is this not the case? any help would be stupendous
cherrington17 05-16-2006 07:27 AM
75/35 fit our cars.
size does matter in this case, since you have limited space, to fit the battery in the holder. you don't want it bouncing around under your hood.
acold7dusta 05-16-2006 08:18 AM
itll fit, u just gotta cut the lip in the front to make it fit
Coupe 05-16-2006 09:22 AM
I have an optima yellow top D34/78.
I just had to cut 2 sides off the battery tray with a dremel, it was a whole 1 minute job.
When they say fit they mean fit in the battery tray, any 12v car battery will work (depending also on side or top posts but with optima they have both).
steve-o 05-16-2006 11:44 AM
same here, just modified the battery tray.
alerochick242 05-16-2006 11:45 AM
Modifying the battery tray is the easiest way. You can also put the battery in the trunk- places like Summit and JEGS sell kits. I have an aluminum battery holder designed specifically to fit Optima batteries mounted in my trunk (frees up space for my intake!).
Coupe 05-16-2006 01:03 PM
Ive been thinkin about runing it to my trunk also to free up some room and even out some weight.
white04alero 05-16-2006 02:11 PM
thanks for the help guys..
sorry.. but even out weight? its a whole 30 lbs.. i respect you man but that sounds kinda ricer-ish to me.. seems to me that it wont make any difference at all.. you dont hear about ppl relocating the battery to the trunk for even weight distribution.. they do it for room.. trunk batt kits do nothing for performance.. what so ever
Cliff8928 05-17-2006 03:22 AM
Then why does a BMW 325i have the battery in the trunk, yet a 318i has it under the hood? The 325i actually does have the battery tray under the hood too, it's just not used. I know it's not alero related, but still.
doubleN0alero 05-17-2006 08:33 AM
and caddys have them under the back seat....what are we arguing here?
Cliff8928 05-17-2006 12:43 PM
Yes, but in the caddy it's a design point of the car. I was comparing ONE model where the battery is in the front on the lighter 4-cylinder and in the back on the heavier 6-cylinder. Certainly there must be SOME reasoning for that.
Alero2k4 05-18-2006 12:08 PM
Yeah, but it is a 60lb weight shift. You take 30 off of the front and add 30 to the rear. That kind of stuff can make a difference. It may just be the difference in a well balanced car and one with understeer. Now I'm not saying that a battery alone with make your car corner better...but if you do quit a few different things then it just might.
Coupe 05-18-2006 02:18 PM
Originally posted by Alero2k4+May 18 2006, 04:08 PM--><div class='quotetop'>QUOTE(Alero2k4 @ May 18 2006, 04:08 PM)</div><div class='quotemain'><!--QuoteBegin-white04alero@May 16 2006, 11:11 AM
[/b][/quote]
You pretty much summed it up for me, thanks.
Every little thing you do adds up.
Alero2k4 05-19-2006 06:02 PM
No problem man.
white04alero 05-21-2006 02:24 AM
wow... you guys sound like the kid at school who drilled holes in the top of his airbox in his civic to add horsepower
Coupe 05-22-2006 01:24 PM
Thats not anywhere near the same thing.
FormulaNERD 05-22-2006 02:17 PM
you're such an idiot. this is completely different. and by the way, civic, alero, etc, it's all the same, drilling out the airbox will do the same thing a WAI will do (though you better swiss cheese the BOTTOM of the box, not the top.)
look at it this way, car company A designs a 4cyl car with near 50/50 weight distro.
later said car company comes out with a 6cyl version of the SAME car. now the weight distro is all f***ed up and it understeers like a mofo. solution?
throw the battery in the trunk with a full spare and you're looking at 50/50 weight distro again.
alero440 05-22-2006 03:23 PM
yep... doing that with the Nissan since the RB motor is heavy then the stock KA motor. Also where the battery fits in the Nissan is right where the exhaust manifold and turbo are going. This is nothing like drilling holes in an airbox. This is just common sense.
pimpalero2003 05-24-2006 06:11 AM
hey i was really bored and couldnt sleep so i drilled holes in my airbox yes i know im gay. But quess what i didnt get ne more power but it does give me a differnt sound from the engine. Ok now everybody give me crap i deserve it. AND IM NOT A RICER!
