-   -   Mileage vs. problems (http://www.aleromod.com/forums/showthread.php?t=1395)
Oldsmopimp 03-07-2004 01:23 PM
...I tried to search for this, but came up with nothing...hopefully it hasnt been done before.
Just list your year, engine, mileage, and any major problems youve had along the way. If no problems, list the mileage anyway..
I'll start it off,
2001, 3400 V-6, 36,000miles
faulty oil sending unit at around 20K, small water leak into drivers side back seat floor. Bad front rotors, and now....intake gasket leak.
misslindseysue 03-07-2004 01:56 PM
2000 3.4V6
15,000 - EGR valve "stuck open"
20,000 - Front pads, all rotors turned
38,000 - Right front hub
45,000 - Front pads and rotors
58,000 - Intake Gasket, new wires and coil
67,000 - Needs: left front hub, front rotors, all pads, repaint hood
Those are miles, and are approximate, I don't exactly remember
jabartram 03-07-2004 02:33 PM
2003, V-6 with 32,000 miles
no problems so far, for me at least, but I purchased it 23000 on it!
smokinAMD 03-07-2004 02:43 PM
1999 V6
36k Standard 3400 gasket leak
41k Tie rod snaps, thus causing me to spin off road and destroy all the right front suspension.
42k Need new front rotors and pads, not immediately, but I need them within the next couple of months.
Now the question is, power slot rotors or powerstop cross drilled rotors?
acidethereal 03-07-2004 04:11 PM
I had the gasket leak thing too I think this needs to be investigated and we deserve a refund for this bullpoop. GM is about a half a second away from me seeking into a class action lawsuit. There is a tsp on this but not a recall......I think thats bullpoop. Once again we find GM lacks responsibility and quality......However I love my car and the community associated with it because thats what it is,.......MY CAR
King Asoka 03-07-2004 04:41 PM
2000 3.4L
26715KM steering gear replaced (under warrenty)
33049KM front pads replaced, machined rotors
45889KM intake leak (Goodwill)
49000KM replace front rotors and pads, new parking brake control.
and i just turned 50,000Km, switching to synthetic!
AlbinoMonkeyRat 03-07-2004 06:22 PM
2000 2.4L
about 39000 miles: washer fluid gasket/grommet disintegrated when the battery was changed (it was apparently the wrong size...)
about 42000 miles: rear window regulator breaks
and at slow speeds AND gentle braking, the left front makes a whistle. :blink:
currently approaching 44000 miles, and no mechanical issues under the hood so far. :thumbsup:
keytonic 03-07-2004 09:27 PM
'99 3.4
bought it with 37k miles I've had it for 2 years now
38k bad water pump
42k broke driver side spring(monroe muffler wanted $850 to fix this got it done at another shop for $90)
45k bad power steering pump
54k bad bearing
55k replaced brake pads
now has 56k
brsexton 03-07-2004 09:35 PM
I have a 2003 2.2L Ecotec with 18K
10k The air bag had to be replaced because the horn was getting stuck.
16K Front Rotors and brake pads were replaced.
aleroman8 03-07-2004 10:09 PM
2001 GLS 2.4L
4 miles - right headlight bulb kept blowing out (literally shattering).
Dealership replaced wiring after four tries.
4 miles - right heater duct didn't work (no hole was made in the duct).
Dealership replaced.
5000 miles - Heater control box replaced (stopped working).
11,000 miles - right rear speaker blown
dealership replaced
11,500 miles - right rear speaker blown again
dealership replaced (even after saying it wasn't blown, but it was)
11,600 miles - yet again right rear speaker blown
yet again the dealership said it wasn't blown
and after arguing for about an hour, I went to
an audio shop and they said it was blown and I
had the wiring and both rear speakers replaced
(2 - Alpine Type R 6" x 9") no problems since
23,000 miles - head unit goes bad
dealership said there was nothing wrong with it (except the
fact it didn't work at all) and after calling GM, they
finally replaced it with one that wouldn't play cd's
so they replaced it again with one that you couldn't read the
display panel, and after they replaced that one ,I replaced it
with an Alpine CDA - 7894 and no problems since
Going on 69,000 miles - no other problems except cosmetic damages along the way :thumbsup:
j{}n 03-07-2004 10:26 PM
i laughed my ass off when i saw this
anyway
99 2.4L
got it with 46000 on it in '02
now has 89000 :eek: (i travel a lot :rolleyes: )
no real problems :knockonwood:
replaced the front and rear brakes once since i've had it, fronts need changed soon
the guage cluster used to cut out when i first got it, but it stopped doing that
the tranny would slip and "trac off" light would come on in winter when i'd gun it up a hill without warming it up first
um, the front driver's side wheel fell off, but that was due to overtightening of the lugs on the mechanics end; snapped the bolts. with that came new strut, brake assembly, rotor, fender, side skirt, and i think that's it...
Redog 03-07-2004 11:22 PM
2000 V6
3000 miles transmission coolant line leaking (dealer fixed)
10000 miles car would turn itself off and on while driving (dealer fixed)
30000 miles hazard switch recall fixed
43000 miles hazard switch recall fixed again (don't know why)
46000 miles (right now) working on a leaking power steering pump and just had a fuel leak fixed
fiestyalerogirl81 03-07-2004 11:34 PM
cant remember the exact miles
2000 3400
67,000 miles replaced brakes
45,000 had to replace tie rod
somewhere in there- damage control sensor damaged
and turn signals have a mind of their own, sometimes work and sometimes dont.
acidethereal 03-07-2004 11:38 PM
2000 3400
hey theres a recall on that (turn signals) during this quarter supposedly of this year im calling gm prolly like this week to scedule the fix
Pimpalero03 03-07-2004 11:46 PM
MILES = 45,000
PROBLEMS = ZERO
dopey 03-07-2004 11:57 PM
bought my car in april 2002 36k.....
2 years later im on about 57k i believe.
not 1 problem.
and i dont think people should list brakes as problems. yes the stock brakes suck....... but something like that is normal wear and tear on a vechical. not a problem
brsexton 03-08-2004 07:26 AM
I consider it a problem when it happens at 16K and is fixed under warranty.
blueyezalero 03-08-2004 10:20 AM
2001 2.4 I had the a/c-heater fixed under warranty..would only work on high. I had the hazard switch replaced under a recall last September. I don't remember the mileage but I do have 60,600m now. No other problems that I can remember.
quitlahok 03-08-2004 10:54 AM
2002 v6, bought it almost exactly one year ago with 24k on it, now at 38k. only problem I have is my power windows are kinda screwy, the driver side one is almost off the track and the passenger side scrapes on the way up. big ol' nasty scratch in the glass now... driver side started in january, passenger side in february.
Oldsmopimp 03-08-2004 07:00 PM
So theres no-one with 100K yet? I figured somebodys gotta have a 99 with around that for miles.
