Water In Fuse Panel
Hello,
I was wondering if anyone else has the same problem as me. When it rains the water somehow gets into my driverside fuse panel and the car wont start. My alero is an 99 3400. I checked the water diagnostics thread and nothing there. Any help would be great, Thanks. |
Fuse panel as in the fuse panel on the left of the dash?
1. Cracked glass 2. Bad seal on the driver side door. 3. A hole in the firewall leading to fuse panel (not likely) |
I have water comming out the bottom of the pass. side dash, I'll check later. It's raining today
i had water on the rear floor of the passenger side. when i pulled the back seat out to lift up the carpet and dry it I discovered it everywhere. I just finished pulling out both front seats and the center console to dry it as much as I can. Now i've got all the carpet out to and i soaked up about a 1/2 gallon of water and everything is airdrying. How do I find where the water is coming in? Anyone else have this problem?
