-   -   Ignition Switch (http://www.aleromod.com/forums/showthread.php?t=15611)
stinger 11-26-2006 02:16 PM
Ignition Switch
I need to remove the ignition switch in the dash of my '00 Alero. How do I do that?
Mark
AftermathAlero 11-26-2006 02:52 PM
simple 3 - 9/32 or 7mm bolts. 2 after u pull out the gauge cluster trim & one behind the radio on the left side.
stinger 11-27-2006 01:19 PM
RE: Ignition Switch
Since one key opens the trunk and starts the ignition, I was thinking about taking the trunk lock out. Is there a trick to it? Believe it or not, both keys to the car are missing and it's way less expensive if I take the lock to the locksmith instead of having them come to the house.
Mark
AftermathAlero 11-27-2006 01:20 PM
trunk lock is a pain to take out.
sound_xtreme 11-27-2006 02:26 PM
the trunk lock is rivoted in. so you have to drill the rivots out then when remounting use bolts/nuts. not to mention that u have to take that stupid ass panel off. the ignition switch would be easier
Cliff8928 11-28-2006 03:09 AM
Mark
You know you can go to the dealer with your VIN and proof of ownership and they will cut you a new key right there...
stinger 11-29-2006 12:44 AM
RE: Ignition Switch
That's exactly what I did today. So that problem is solved. Now I've got to work in the bigger problem, replacing the water pump (the bearing is bad).
Mark in Vegas
Cliff8928 11-29-2006 12:50 AM
I hope it's not a Twin-Cam.
