transmission jerks
i posted a similar question a while back like this. when my car is at normal operating tempature, my car will shift into 2nd and 3rd very hard. if a drive like a grandma and accelerate very slow, it wont do it, but once i accelerate a little faste, it will start to jerk. car has 75,000 miles, tranny was flushed 4,000 ago because thats what most people said it might be. 500 miles ago i added seafoam transmission tune, and that did nothing. wth could it be? also forgot to add, the engine makes an odd noise at idle in drive at a stop light, but when put in park, it sounds normal.
That's exactly what mine does. Has the power as long as you slowly depress the gas, but hit it and it feels like it's struggling for those horses. I was just gonna change out my trans fluid tomorrow. Hope that does something
that's what mine used to do. forget changing the fluid. i changed the tranny. lol
Wooooow. That's alittle more than i'm looking to do, but I have no other problems with operation other than when I mash the gas. Does this sound like imminent tranny failure?
no, not necessarily.
my car had 1/3 more miles than you when the thing went. my engine was quick to follow suit. lol take it to a specialist. get their opinion, and then come back to us. |
Lets not get it confused. That is rev's mileage. I just hit 120,000 the other day |
that was my lucky number. good luck.
Here are the most common problems with the 4T65-E transmission that will cause a harsh shift upon heavy acceleration:
• All years--Pressure Reg. Valve (Bore 1) or Torque Signal Valve (Bore 4) stuck. • On 2001-2002 vehicles, a plugged orifice on the case side of the spacer plate. • ON 2003-2004 vehicles, restricted movement of the 2-3 shift valves in the valve body. • On 2003-2004 vehicles, restricted movement of the 3-4 shift valves in the valve body. |
Well, I fall in the "all years" catergory. So, is this home mechanic repairable?
Any SES lights? I solved a similair problem on a grand am, turns out to be the TPS faulty. Does it lag when you stomp on the gas? Feel like a misfire? if so then it may need a tune-up.
Mine was doing the same exact thing and i had to get a new tranny. $1400 dollars later.
i think i paid 200 dollars total. i did all my own labor, and picked up the tranny for 85 bux.
good tranny fluid is expensive. royal purple ftw |
Yea same problem with me, I just hit 101,000 and the shaking from the tranny while in drive while seating at a light is horrible, I always have to put it in the neutral, Im thinkin my tranny is goin to shit. Whats new on our cars huh lol
you may just need fluid added. mine did that crap when it needed fluid.
nope changed my tranny fluid yesterday, still the same, and I put that good shit in too (Royal purp) my tranny just goin out, Im thinkin maybe a syncro is goin expecially between 1st and 2nd its a long paused shift, like its slippin too..inless I floor it then it shifts firm and hard like its suppost too.
if he has a 3400 its a 65 |
its actually 4T40, the 45 is in the GAGT and the 65 is in the chevy's and grand prix |
Yep, the 65E is only in the larger (ex: W-Cars and larger)... Just ask a dealer mechanic / parts guy.
The ONLY time a 65 gets installed into one of the smaller cars is the newer ones with the 3900 V6. |
You have no synro gear in an auto, synro are only in manuel. |
