-   -   Rattling sound over 59-60 mph (http://www.aleromod.com/forums/showthread.php?t=16021)
Vinalero 12-30-2006 02:37 PM
Ok here I go again. Yesterday I was on the Highway, and when reaching about 60 mph, a loud (really loud) fast rattling noise appeared like right in front of me in the engine bay. It's A sound like a vibration a bit like when you roll on those stripes they made on the border of the highway that when you leave the road and your tire enter the stripe it makes a loud noise to prevent you from goin asleep (I dont know if you get what I mean). It also sound like when we were young and placed cards in our bycicle's wheels to sound like a motorcycle.
Whenever I get back under 55 mph, the noise stop. I did it a couple of times, and everytime I get over 59, it appears, and disapears under 55. Under that speed, the car doesn't do a single noise and drives normally. What could it be? :(
super white alero1 12-30-2006 03:05 PM
Check ur plastic liner under the bump.
PFC2 12-30-2006 03:09 PM
check to see if anything is loose first and go from there it could be numerous of things
Vinalero 12-30-2006 03:29 PM
I already check, no plastic is loose beside or behind the wheel, and even if one was, it would do some sound below 55 mph. I haven't taken the wheel off, but i looked around by turning my wheel on both side and nothin seems broken or loose. Again if something was loose, it would emit sound below 55. And if something was broken, I assume it wouldn't drive normally either.
Is there a speed sensor somewhere on Aleros that regulate something in the drivetrain/brakes/suspension or transmission that could malfunction? I wish I knew a mecanic with a garage :(
The best would be if someone already had this issue with his car and got it fixed.
Vinalero 12-30-2006 04:07 PM
I just red in my haynes that there are speed sensors in the bearings that tells the EBCM the speed of the wheel. Is it possible that the speed sensor is bad and that over 60 mph, he gives a wrong imput to the EBCM that then ask the hydrolic clutch to activate even though I don't have my foot on the brake?
Redog 12-31-2006 12:07 AM
That is a possilblly. The ABS hubs in these cars suck. They are so fragile.
If something was loose you'd feel it long before 60. I could hear a grinding nosie at 27 MPH and up when one of my hubs went. It wasn't like your though. Fixed under warranty
Twiz 01-02-2007 04:51 PM
I'd check the drive axles to see if their boots are torn, if not then your wheels may be out of balance. Usually if the wheel bearings are at fault they start to make noise when you drive 30 mph or more. I'd say you need your wheels balanced, specially if your steering wheel vibrates around 60 - 70 mph.
Vinalero 01-03-2007 12:39 AM
I'm goin in a garage tomorrow, i'll ask them to check on the drive axle. That's the flex thing with a rubber boot over it that is linked to the trans? I thought about it.
Also, I have a new Tie rod end on the side the noise appeared, but not the day it was replace. Still, my car was goin a bit on the left side before I changed the Tie Rod. When they changed it, they aligned the car afterwards (the car was still on the align jack when I got back at the shop). But still the car continue to get a bit on the left if i let the steering free. I though alignment would have fixed that. Maybe the noise is related to that.
I would be so happy if it was only a balance problem.
Ghadsphi 01-03-2007 01:07 AM
Probably a dumb comment but, might want to enlist a buddy to listen and try to pinpoint if it's comming from one side or the other, let him/er ride shotgun and drive so you and them can hear the diference leaning out the window. Anything at a decent speed (not rolling down a driveway) can be little easier to pin point from more positions than the drivers seat.
Vinalero 01-03-2007 05:06 AM
Since the sound is coming only over 60 or so mph, I can't really hear it rolling down a driveway hehehe, but still tonight when I got back home, I opened the window and got to 60, Noise appears, but with window open it sounds different. It really sounds like scraching rubber. That's why I welcome Twiz Idea of the drive axle or unbalanced tire. And I can definitively say it comes from my front left wheel. I can say its right in front of my left foot.
Maybe tomorrow I'll know. Let's just hope it won't cost my balls out.
olds2race 01-03-2007 07:11 AM
does the steering wheel shake?
Vinalero 01-03-2007 10:26 AM
Nothin really noticeable.
Vinalero 01-03-2007 05:32 PM
<------- Got Owned real hard.
Just back from garage, got my rear brakes changed and emergency brake tighted. The mecanic and me checked everything that could possibly make that freakin noise. I got my 4 wheels rebalanced, even though they were terribly unbalanced, it wasn't it. Did a little road test to find that it was doin it again. Took it back on the lift, checked back, then got the car down and I flashed on the deflector on my hood...
Previously the day I first noticed the sound, I went to an automated carwash and under the blower to dry the car, wind caught the deflector that almost came at a square angle with the car. I didn't really put a lot of attention to it because it was still there and didn't break. But the 2 outside pins of the deflector that hold him on the hood are not there anymore and it's really possible that at a higher speed, the wind makes him clap rapidly with the hood.
I'm not sure it's really that, but it seems it could be a really plausible solution.
