-   -   Turn signal issues (http://www.aleromod.com/forums/showthread.php?t=16035)
dustin 01-01-2007 03:20 PM
Turn signal issues
I'm having a problem with my turn signals. After I use them, in either direction, the car continues to make the clicking sound. It will click at a fast rate, slow down, and stop for a few minutes then start up again. I'm wondering if anyone has had this same problem. It's a 2000 Alero 4dr sedan. Thanks!
Mischief007 01-01-2007 04:20 PM
If you searched, you would have found the answer:
http://www.aleromod.com/forums/showt...nal+click ing
Look at my post which is number 9.
olds2race 01-01-2007 04:30 PM
Ihad a similar problem when I broke this little box that was mounted on the inner fender Left side.If it isn't grounded properly it makes a fast clicking at your flasher and all your turn lamps light up no matter which way you throw the switch.
dustin 01-01-2007 05:18 PM
Thanks Mischeif007. Sorry for not searching :(.
