-   LA1 3400 Specific (http://www.aleromod.com/forums/forumdisplay.php?f=19)
-   -   intake manifold gasket... (http://www.aleromod.com/forums/showthread.php?t=16081)
cavaliers60 01-04-2007 04:32 PM
I got mine replaced after finding out it was leaking... But I was just wondering if it will happen again and how often does that happen????
super white alero1 01-04-2007 04:36 PM
Very often, if the shop use the Felpro gasket with the metal backing then you should not have to do it again for about 2 yrs.
Ryan from Ohio 01-04-2007 07:17 PM
DO yourself a favor, ditch the orange coolant and go back to the regular green stuff!
cavaliers60 01-05-2007 07:24 PM
I think I have the regular green stuff.. and I think he did use that Felpro.... I'll have to check...
Exit9alero 01-08-2007 12:19 AM
wait wait wait we can use green coolant in our aleros????
Cliff8928 01-08-2007 12:50 AM
You can use the green stuff, I don't see it being any advantage aside from being cheaper. You have to change it more often too, and it contains silicates which are more prone to causing that scaly build-up in the cooling system.
Ryan from Ohio 01-08-2007 05:59 PM
Yes you can.
I guess the old stuff and the Dex Cool are not compatible though...
The stores are now stocking some "yellow" stuff thats compatable with both styles...????...
There has been numerous complaints about Dex Cool eating up gaskets. So many their are class action lawsuits still current against GM over them.
Also note, them quick lube shops wont use the green stuff in your car. Because the sticker says "dexcool only" and because they charge you $80+ for dexcool and only $35 for the green ;)
El_Diablo 01-08-2007 06:36 PM
dex cool sux... swap it out but flush first unless you want your block to be a giant jello mold ;)
Kingpin 03-16-2007 12:53 PM
I've just dicovered that my intake manifold is leaking too... not too impressed. I've only had my 2003 Alero GLX for 4 months and it seems to plagued with problems.
comanche 03-16-2007 12:57 PM
I was told by a mechanic that a gasket is a gasket... eventually it will have served its' intended lifespan and need to be replaced.
My LIM gasket failed at 39k on my last V6. Right now I've got 22k on an OEM gasket, and I've heard of them failing at that low of a mileage.
Gr1m 03-16-2007 01:00 PM
LIMG at 22k? loooool im at almost 80k and nothing *knocks on wood*
comanche 03-16-2007 01:20 PM
Someone on here or grandamgt.com was complaining about their LIM going at 22k. miles. Maybe you are just getting lucky...
Ryan from Ohio 03-16-2007 10:58 PM
Well a gasket may be a gasket, but the Dex Cool vs the green schtuff is two very different beasts...
Ive went almost 96K miles on my LIMG and just changed it out with the steel Fel Pro- its the $85 perma-dry plus one. Rock has it for $69 ;)
SweetNLow 03-16-2007 11:24 PM
80k is abit on the highside......... it will be going soon.
and the reason the gasket fails IS NOT BECAUSE OF DEX COOL!!!
its due to the material the gasket was/is made out of. it expands and contracts to much when it heats up nad cools down and lets coolant seep thru it. gm supposedly has corrected this problem now in the 3500's but who knows.
Cliff8928 03-17-2007 12:26 AM
The new 3500 and the 3900 don't have the problem because there is no more coolant going through the intake..
The problem with the Dex-Cool is that when the system is low in coolant, the dye pigment precipitates. If it's kept full, there's no problem.
strtrydr 03-17-2007 02:16 PM
I'm at 77k and dont have the problem either ... yea and definitely *knock on wood*
AsianAlero 03-17-2007 05:41 PM
i had a jasper put in my car and now im running regular coolant. dexcool corrodes the seals and gaskets that why theres a class action law suit
also i heard that the gasket in the alero was made out of shotty cheap material by gm. they have change the part number because they made a new one or something like that
Cliff8928 03-19-2007 12:26 AM
The original gasket design was faulty, however there are no issues with the dex-cool if you properly maintain your vehicle and keep the cooling system full.
Gr1m 03-19-2007 12:50 AM
i just replaced mine the other day because of problems i was having, turned out it wasnt the gasket that i thought was causing a vacuum leak but it was my iat pigtail harness was fried that fixed my problem
