-   -   Alero is DEAD! (http://www.aleromod.com/forums/showthread.php?t=16118)
natedawg9640 01-07-2007 09:16 PM
Alero is DEAD!
hopefully somone can point me in the right direction... went to shopko and everyhing is fine... come out to start my car to leave... it fires and dies right away... try to start it again and all it does is crank... got a half tank of gas, battery is strong, turns over fine... i can hear the fuel pump whine when i leave in in the on position for a sec... what could be the problem? and more over, what could i do to get a great diagnosis in the shopko parking lot... i was thinking ignition control module? <--- how much is it and how hard is it to switch?... or mabye the coil packs? how much are those? and what's the most likely scenario... any helpful ideas would be great... i dont have the money to get it towed and fixed if i can help it... thanks a lot guys...
sound_xtreme 01-07-2007 09:36 PM
security light flashin?
bigfrye 01-07-2007 09:50 PM
try
Try to pushing the throttle just a little incase your IAC is stuck. Test fuel pressure on the rail.. test your spark. Replacing your ICM may take you 20 minutes at the most.
natedawg9640 01-07-2007 10:08 PM
after i try and crank it over, yes the security light flashes... i did try pumpin the gas a bit...
clutch1 01-07-2007 10:09 PM
You got a passlock issue. I had it this summer. My sensor ended up needing replace ment, but sometimes if you pull the battery for a while it'll reset and oyu'll be ok. I forget the other trouble shooting methods.
Ryan from Ohio 01-07-2007 10:29 PM
crank position sensor?
jackal2000 01-07-2007 10:33 PM
the security light will flash for 10 minutes and then you should, in theory, be able to start to car. my car was like this for a couple months before i had the money to replace to the ignition.
sound_xtreme 01-07-2007 10:42 PM
yep, turn the key to on and leave it sit for 10 minutes. you might need to disconnect your headlights so battery dun go dead
GoldStar611 01-07-2007 11:54 PM
or put the e-brake on
MixtapeMessiah 01-08-2007 01:14 AM
ur keyless entry bullshit security system wont let u start it thats whatsup, happened to me and I ripped the alarm out lol
sound_xtreme 01-08-2007 01:22 AM
thats you were a dumbass and tried to uninstall it yourself. let pros handle it. remote starts require a bypass for passlock II and require cutting a passlock wire. if you just "rip" shit out you can expect other shit not to work right.
natedawg9640 01-08-2007 01:37 AM
well i dont have keyless entry...
so you are saying its a passlock issue? what's that? and what needs to be replaced if that is the problem? any idea what it'll run me? i hope that's the problem... then at least i'll be able to get it back to my house.
so i turn the key to the "on" position for 10 minutes... it should then start up again... if not... try disconnecting the battery for a little while... and if that fails?
sound_xtreme 01-08-2007 10:52 AM
you may not have to replace anything, but most likely the sensor is goin bad
disconnecting the battery wont do anything. turn the key to on without trying to start it. leave it sit for 10 minutes, security light should go off. you should be able to start it then.
if that fails, ur effed?
natedawg9640 01-08-2007 01:28 PM
sweet... gonna go give er a go
El Pablo 01-08-2007 02:03 PM
i take it all went well?
Gr1m 01-08-2007 02:32 PM
ya he went to go pick up his girlfriend at her junior highschool thats why he hasnt replied yet ;)
natedawg9640 01-08-2007 02:57 PM
haha... not quite...
nope... no go. turned key to on, left it sit, still won't start... disconnected the battery for a sec... still won't fire...
when the key is in the on position, there are a few lights on but the security light is the only thing that flashes... what do i have to do to replace this sensor or whatever? and where is it? and if it's not that passlock thing... then wtf is wrong with my damn car...
oh... if it helps, it's a 2.4
keep in mind it's in the kmart parking lot so i am limited in my ability to perform service to it... if there's anything i could rip out and stick a new one in that is probably the problem i could do that... any other check to rectify the passlock issue?
teflone 01-09-2007 03:35 PM
spare key
use it.... lol
natedawg9640 01-09-2007 03:49 PM
tried a spare key...
natedawg9640 01-09-2007 04:01 PM
i dunno what happened the first time i tried the passlock resolution but it worked this time... thanks guys... this site is a great tool
