On the gls there is a little compartment in fornt of the shifter. In this compartment there is a light bulb that is on and i was wondering what type of bulb this was so i could try and change it to a blue......any ideas on what type and size this bulb would be?
i believe it's a 212-?, i turned all my interior lights to blue and instead of buying them i went and bought sharpie permanent marker in blue and colored all of my bulbs.... works absolutely great with no peeling
Replaced it with LEDS.
ditto |
How did you replace them with LED's?? How did you make them fit and where did you find them?? Did you get the LED's off Oznium.com? Thanks
I ordered them from oznium. Take out the radio bezel and the light comes out with it. Find you positive and negative wires, splice/solder according to ozniums directions and your set. As far as making them fit, they are really small.
Same method. Only thing different is wrap the two led's with electrical tape, to kind of make them fit in the hole. |
Thanks everyone fro you answers im looking into all those options....thanks again
I did the LEDs too, but I do recall someone else asking this before and someone else (maybe Nick) said that you can't get a replacement bulb for that. I guess the little clip and the bulb are all together or something like that. So any kind of replacement is going to be somewhat custom. Any bulb/LED will work, you'll just have to figure a way to hold it in place.
LED is the way to go in the cubby hole. I also wired mine to a switch so the SOB doesn't stay on at night all the damn time.
will a 194 bulb fit into the rear side marker
I had a light bulb question: what are the fog light bulb numbers? (for the stock fog lights) and what are all the bulb numbers for the headlight assembly, i know theres 9005,9006, but what are the other 2!? :wacko:
oh yeah does anyone know where i can buy yellow LED's just like the little individual ones from oznium? :ph34r: thanks
The outer turn signal bulb is a 194 and the inner is a 3157. If you put a LED 194 in your turn signal, don't bug out when it starts blinking faster. The LED just uses less voltage, so it blinks faster.
:blink: if u have a 2000 alero dont put l.e.d. 3157's in your headlight assembly , i blew my hazard relay switch , even though it is a recall it was still a problem when i had no turn signals and no hazards for 2 weeks
i still need to know the light bulb number for the stock foglights, anyone know?
for all bulb info, go to http://invision.aleromod.com/index.php?act...ge&f=lightbulbs
im having some trubble on trying to find replacment bulbs for the foglights, cause i was thinking about makign those bulbs yellow, and puttign in new foglights or just put in some blue bulbs, i dunno yet but help me out with a link for foglight bulbs, thanks :D
