-   -   Pos Gm (http://www.aleromod.com/forums/showthread.php?t=16551)
Wreckless 02-11-2007 02:58 PM
Pos Gm
My e-break light is coming on intermittantly while im driving,and when its on the cruise doesnt work any ideas on what this might be.I havent looked at it yet I just thought Id ask here to see if someone has had the same problem.All I know is that Im getting sick of the crap going wrong with this car its always something. Can GM make a vehicle in which everything works for more than 5 or 6 years?I doubt it.
SweetNLow 02-11-2007 03:35 PM
ive never seen a car that doesnt have some "issue" within 5 or 6 years.
i guess changing your oil is a problem for you as well?
Mischief007 02-11-2007 04:05 PM
Advice to you. Trade it on a bicycle. I hear they last a long time.
Vinalero 02-11-2007 04:14 PM
I gotta agree with Wreck, I know a vehicule comes with some issues, but of all the cars I've owned, the Alero is the one that has the most wierd things happening. I've never been to the garage as often as in the past 2 months.
And now, I think one of my hubs is going, yesterday the SES, ABS and Track off light came on all at same time, but disapeared when I restarted the car afterwards.
14alero 02-11-2007 04:52 PM
its a car stuff happens
BlackJack 02-11-2007 05:06 PM
every car made can last 5 or 6 years without something going wrong with it. All you have to do is buy it new, park it in a garage, put a tarp over it, and dont touch it.....ever. I can say with great certainty you'll never have a maintenance problem no matter who makes it.
DaRockwilder 02-11-2007 05:26 PM
Check your brake fluid level? the cruise not working while the e-brake light is on might be a saftey thing.
Wildman 02-11-2007 05:31 PM
Originally Posted by Wreckless (Post 256058)
My e-break light is coming on intermittantly while im driving,and when its on the cruise doesnt work any ideas on what this might be.I havent looked at it yet I just thought Id ask here to see if someone has had the same problem..
Ok, since nobody seems to want to be helpful, lets take a crack at the question he has...
Does your low trac or trac off lights come on also with the brake light? Could be a wheel speed sensor on the fritz. Have you had any of the front wheel bearings replaced since you have owned it ?? Also, does the light come on and stay on, or does it come and go while you are driving?
Wreckless 02-11-2007 08:09 PM
First off Thank you Wildman and DaRockwilder for your advice it is much appreciated,and to everyone else who had a smart ass coment I do appologize for insulting the holy grail of vehicle manufacturers GM .I suppose that when I pay good money for something I expect it to work properly not crap out on me every 4 weeks,but if thats what a good car does Im going back to an old Ford truck I had that never gave me any problems what so ever.I do realize maintenance is the fact of owning a car I have no problems with that.But having to turn or change the rotors once a year is bullshit.Its the exact same thing with the GA as well. What the hell is up with that ?
Wreckless 02-11-2007 08:11 PM
Maybe Ill trade it in on your MOM, SweetNLow says shes a good ride.
Wreckless 02-11-2007 08:16 PM
The trac light comes on when its supposed to not with the brake light.I did have the rear drivers side hub and wheel bearing replaced last spring after an accident.The light mostly just comes on and stays on but it does go out every now and then.
Wreckless 02-11-2007 08:20 PM
Thats what I was kinda thinking as well it would make sense,you hit the brakes when your cruise is on, it turns it off I just gotta find out why the light is on.Off topic but you guys getting lots of snow as well in Red Deer?
BlackJack 02-11-2007 11:20 PM
stay on topic. yes, the cruise not working IS a safety thing, just as if you tap the break pedal when cruise is engaged. Start with the simple stuff and see if the e-brake sensor is shorting or going out.
Wreckless 02-11-2007 11:32 PM
Thanks.Ill give it a look and see what I can find tommorrow after work.
Cliff8928 02-12-2007 12:00 AM
Definitely start with the fluid check, there is a sensor in the reservoir that will usually turn on the "BRAKE" light on the dash if the fluid is low.
sorrowfulkiller 02-12-2007 12:02 AM
Could also be a live wire interfering with the e-brake line... Time to pull apart the center console!
Oh and about rotors... this is why I'm changing out all my rotors for aftermarket Drilled and Slotted. I figure, why waste more money on OEM parts (in the long run) that are ALWAYS going to warp, why not go with aftermarket ones from a trusted company so you know they won't warp?
SweetNLow 02-12-2007 01:03 AM
i was actually reading about the warped rotors the other day....... its more of a oem pad issue than the rotors
alerocar01 02-12-2007 10:17 AM
wow i always thought it was the alloy of metal they used in the rotors that caused them to warp. i guess not.
Mr_Reed 02-12-2007 10:29 AM
I agree with Wreck GMs quality sucks
My cars a 2001 and has 71,000 miles on it and has more problems than my 1993 Ford Festiva GL with 300,000 miles on it.
(Festiva has a Mazda motor and a Kia body) But still they put a better car togeither than GM does..Also my dad had a 1998 Chevy S10 Blazer and man it was a piece had problems out the ass..
HazMatt24 02-12-2007 10:40 AM
the battery will die, stupid battery manufacturers not making batteries that last forever.
