-   -   Train horn setup is killing my car (http://www.aleromod.com/forums/showthread.php?t=16553)
Redog 02-11-2007 09:22 PM
OK I hooked up the horn today, I hooked the switch and compressor to the fuse box bolt. After hooking everything up, the car wouldn't start.
So I figured that the compressor line, which I put under the main wire, was interfering with the connection from the battery to the car so I undid that and the car started, weakly
The battery light came on, and I finally got the car started (after 3 tries) and it almost stalled, dropped down to 500 RPM and then shot back to idle and ran fine.
My dome light is dim and it flickers a bit, then stays lit normal after about 1 min. The gauge pod gauges are jumpy too. More so the voltmeter than the EGT gauge.
So I drove the car about for about 10 mintues, and it's still hard to start.
The train horn is going to get it's own battery, I can't risk the car breaking down like this.
How bad is my situation? Do I just need a good charge, or did I eff the alternator?
sound_xtreme 02-11-2007 10:07 PM
uhh, id say you should take it to a pro and have THEM install it. cause it sounds like you hooked it up wrong
bigd6983 02-11-2007 10:18 PM
yea im with soundextreme.....you had to have wired it wrong somehow....what are the connections like?? does it have a relay? what wire hook ups are there? i doubt it pulls that much power that it wouldnt allow your car to run right, do you have a link to the horn maybe?
Silentalero 02-11-2007 10:52 PM
yea dood i have mine connected to my battery and i just have a cutoff switch for it. Sounds like your pullin to much juice. Put a cutoff switch on the compressor
its fine while the car is on but if its off. its a killer
Redog 02-11-2007 10:56 PM
Yeah I think I'm going to hit up a pro :(
doubleN0alero 02-11-2007 11:01 PM
again...seems like sooooooo much hassle to go through for a horn...
sound_xtreme 02-11-2007 11:09 PM
it's not if u know what ur doin. we'll hook it up at ASS, lol
Silentalero 02-11-2007 11:12 PM
/\ true, it took me a hal hour to wire it up.
Wreckless 02-11-2007 11:49 PM
Why you would want a train horn to begin with is beyond me but I have to say I admire you persistance to get this thing working.Id deffinately have a good laugh if I heard a train horn in a car when someone cut them off.LOL
Satsuriku 02-12-2007 12:27 AM
if i could i would soooo get a train horn!!! ive never had to use my horn on my car yet and ive had it for almost 3 years........sorry, i used it once!!! lol
SweetNLow 02-12-2007 01:08 AM
wiring is a bitch to someone who doesnt really know whats going on.........
brad remeber when you stopped by my place back in the summer time and my car was just sitting in the driveway? it was just sitting there cause i took my air tanks our and unwired abunch of my valves and shit and ended up effing stuff up. i still dont know exactly what i did to screw it up....... or exactly what i did to fix it....... but wiring is difficult if your not 100% positive of what your doing.....
thats why i go out to joels house when i have a big wiring job haha
sound_xtreme 02-12-2007 01:17 AM
you called ME to fix it and walk you through it :x
SweetNLow 02-12-2007 01:18 AM
i did call you but you didnt help much trust me......... in that situion it was like a rocket scientist(you) trying to explain thermal dynamics to a monkey (me)
doubleN0alero 02-12-2007 10:18 AM
Yes, I do remember the HUGE mess that you had made trying to move your airtank down in the spare tire compartment. That is just something I wouldn't want to mess with. As I said before, if it was for something like air ride, then the headache might be worth it, but a horn, not so much.
A
I also remember your car was laying on a the ground. Low enough that you couldn't get a jack under it...thus I ended up spending alot more on new rotors that I had wanted to, but I guess it happens.
Redog 02-12-2007 01:03 PM
I took the car to the mech today to check the alt and battery out, they are both "low" but he says they should clear up in a few days of driving around. Car started right up this morning with no problem, but after I got home and restarted the car, it started and died, 2nd try, started right up. Voltmeter is at 14, it did spike at one point comming home to 18 for a super quick second (nanosecond) but back to normal ASAP.
The compressor works fine, we did get it running for a few seconds, but the wiring into the relay is were the problem is. He said I have great grounds, and the wiring is good, but he doesn't know the relay points.
I'm getting my windows retinted on Thursday, and they are going to look at it
sorrowfulkiller 02-12-2007 01:48 PM
Like everyone has said so far though... once you get it working correctly... post a vid :)
sound_xtreme 02-12-2007 02:58 PM
1 Attachment(s)
heres how i would do it. if you wanted you could put a toggle switch on the ACC 12v+ Switched. fixed
Silentalero 02-12-2007 05:46 PM
also dood make sure your relay and switch can handle a 30amp line. That was a problem i ran into with mine at first. Its a juice puller.
SweetNLow 02-12-2007 06:01 PM
ya the compressor draws a TON of current....... and another little tip..... dont touch the compressor or the line after its been running for awhile. that effer gets HOT
Silentalero 02-12-2007 07:04 PM
u mean tha air line from it...not the power line, if your power line gets to hot then you have to small awg wire.
