-   LA1 3400 Specific (http://www.aleromod.com/forums/forumdisplay.php?f=19)
-   -   Alero Start-up (http://www.aleromod.com/forums/showthread.php?t=16631)
Midgear 02-18-2007 10:28 PM
Alero Start-up
Finally caught the problem in the act, when i was originally gonna get a sound clip of my cold air intake!
The car starts, gets to about 1000 rpm, and craps out.. i -never- touch the gas pedal in this clip untill the very end of the clip, i'll get a sound clip of the cold air intake tomorrow or somethin. this only happens every 10 - 20 starts, any ideas what would cause it?
http://s178.photobucket.com/albums/w...HPIM1769-1.flv
pimpalero2003 02-18-2007 11:21 PM
looks like u got an electrical problem u need to check wires see if there burn loose disconnected look and ur odometer flash
alerocar01 02-19-2007 12:22 AM
my car does that sometime. it will start then die but it doesn't die two times in a row.
pimpalero2003 02-19-2007 12:37 AM
look at his odomater its going nuts and wow got 2 love patron
Midgear 02-19-2007 05:03 PM
My odometer isnt going nuts, thats just how it was recorded on the camera, i assure you my odometer is fine.. I believe it could be the spark plugs..
mrmike 02-19-2007 10:30 PM
I had this problem, it was a loose battery ground. Out of nowhere it would just need 3 tries to start.
pimpalero2003 02-19-2007 10:58 PM
oh ok i was going to say u got BIG problems bro
TurboAleroGT40 03-05-2007 10:37 PM
Hmm, sounds to me a groud prob, had the same prob a very long time ago.
check the connection at the batt or check the connections of ground inbetween the engine and car body
Midgear 03-12-2007 10:57 PM
how would a ground cause it to stall out?
Gr1m 03-12-2007 11:01 PM
is your security light on? i cant tell from the video
Mischief007 03-13-2007 11:32 PM
My Cavalier did that during cold nights after sitting for a while. Vacuum lines were rotten behind the throttle body. Replaced those and it started starting. I had to hold the gas and make sure it doesn't stall until I drove it for 5 minutes and then it was fine. Could really be anything at this point though.
