-   -   Wheel and tire combo WEIGHT (http://www.aleromod.com/forums/showthread.php?t=17219)
Youngblood77 03-31-2007 05:04 PM
Ok, in order to make an educated decision on a cheap, track-only set of wheels, I'm doing a bit of "web-based homework". The results of my research are being compiled and shared with RegalGS.org, ClubGP.com, MyMonte.com, NewImpala.com, Aleromod.com, and GrandamGT.com......hopefully with the help of all of these sites, us enthusiests may benefit from each other's work @ the track, and same some green in the process. Here's how it works:
I'd like to get the following information from you if you have it:
Post the diameter of wheel you have ( 15", 16", 17", etc. ), and what your wheel and tire weighs together, along with a pic of your wheel for clarification.
THIS PERTAINS ONLY TO OEM WHEELS, NO AFTERMARKET.
If any of you have any links as-to where they show the stock wheel weights of any N or W Bodied cars, please feel free to share that aswell.
Thanks for your cooperation and help,
-Eric
Q: What is the weight of the factory rim (GT and GTP)?
A: torque star = 14-15lbs
A: crosslace = 15lbs? (not 100% sure)
A: flat 5 star = 17lbs-18lbs? (not 100% sure)
A: snow flake (3 star) = 21-22lbs
16" TQ Stars with 225/60/16 bridgestone all season tires weigh 44lbs apeice full of air.
crosslace wheels mounted on 225/60/16 tire = 42 lbs.
15 spoke chrome 16" stock 40th Special Edition wheels with Eagle RS-A's are 46 lbs a piece.
