-   -   Clear corners?!?!?! (http://www.aleromod.com/forums/showthread.php?t=18048)
kniedelm9490 06-05-2007 12:07 AM
Clear corners?!?!?!
ive been hearing all this stuff about clearing the corners of the head lights. if i wanted to do it how would i go about this?
doubleN0alero 06-05-2007 12:12 AM
Here's a thread all about it http://www.aleromod.com/forums/showt...=clear+corners
I hope this helps
kniedelm9490 06-05-2007 12:23 AM
thanks man
doubleN0alero 06-05-2007 12:27 AM
No problem...if you need anything else, just ask...there is a search button up there on the main toolbar if you just type in some search words such as "clear corners" it will bring up every thread related to that. if you can't figure it out though, there's always somebody more than willing to take a shot for ya
CarlitosWay 06-06-2007 03:24 PM
After you clear your corners, do your lights flood when it rains?
p1mptress 06-06-2007 03:27 PM
no just make sure you silicone it back up really good like air tight
TheMeaningOfLife 06-06-2007 04:30 PM
Yeah you really have to seal her up good or youll blow out lights like theres no tommarow. Get the silicon from lowes or somthing. and when applying it, DONT be chinsey with it.
HazMatt24 06-06-2007 04:37 PM
totally off topic, but it relates to a search. I joined a forum for Trailblazers because that's what my fiancee drives and they won't let you use the search function (as well as other things) until you make 10 posts. I guess they want to feel you out first, make sure you aren't spamming and junk
doubleN0alero 06-06-2007 05:18 PM
thats probably one of the weirdest things I've heard. I don't mind helping people out because sometimes they just don't see the search button, but when I help, I TACTFULLY remind them that its up there. The problem sometimes is people just automatically jumping down somebodys throat for not searching first...all the time you wasted screaming, you could have just gave them the info...no big deal.
Anyhow, I agree with above...silicone and use a bunch of it. Not too much that its running out into the lights, but enough that you're going to get a good seal...after you get them sealed up, I would recommend leaving them in the house with some tape wrapped around them applying constant pressure for as long as you can before you throw them back on your car. the natural heat from the sun will losen them up pretty good if you just throw them back on right away.
cherrington17 06-06-2007 05:40 PM
If the plastic is still warm from when you initially heated it, the silicone will become more liquidy, and seep down into the crack better. making something similar to a silicone gasket...
blindman 06-06-2007 05:44 PM
how long do u suggest keeping them taped up and in the house? cuz i might try it this weekend and i dont wanna have to keep them in the house all day cuz i got sum stuff i gotta do.
adam337 06-06-2007 05:50 PM
^if you can 24 hours if not give it at least 5
cherrington17 06-06-2007 06:15 PM
^hahaha.. i let my first one sit for about 20 min (while i was doing the other) and the first one got like 5 minutes (the time it took to get the first one back into the car) silicone sets pretty quick... as long as its dry, you shouldn't have a problem.
blindman 06-06-2007 06:26 PM
what did u guys put in there for lights? and can i see sum pics
adam337 06-06-2007 06:38 PM
^ill get pics for you tonight all you LEGALLY need to change are the bulbs that are in the spot where the reflector use to be Those are 194 you can get them in yellow so youll be good. you dont really need to change them though cops dont seem to notice.
alerocar01 06-06-2007 06:47 PM
^^^ mine are white and haven't had a problem but if you are worried about that then get yellow bulbs.
blindman 06-06-2007 07:17 PM
im actually looking at these sylvania http://www.sylvania.com/ConsumerProd...verStarSignal/
idk if u have heard of em or not but a friend has em and they look nice
adam337 06-06-2007 07:42 PM
I have those. thats what im taking a pic of :p
alerored04 06-06-2007 07:53 PM
i have amber led clusters in 194 and 3157. Had to put in a resistor to keep them from blinking fast but they look nice.
cavaliers60 06-06-2007 09:31 PM
I got those Silverstar ones also... They look nice.
And so you know.... That pic was taken in 2005, not 2003... Haven't had it that long. lol
