-   -   Rubbing noise on front wheel (http://www.aleromod.com/forums/showthread.php?t=18184)
Aldog3788 06-18-2007 01:08 AM
sometimes if i turn to hard or spin a lil the car makes this humming noise thats effin loud and annoying.....it comes from the wheel most def....when i step on the brakes it goes away then comes back.....anyone have any idea wtf is goin on??
thanx-
alex-
00 alero
troyertrain 06-18-2007 10:06 AM
could be the wheel bearing (hub). its very common for them to go bad on our cars...
Vtolds 06-18-2007 10:12 AM
He should have a security light on if his hubs where going I think.
troyertrain 06-18-2007 11:24 AM
^^^yeah, true... when mine went out i didnt get the ABS, LOW TRAC lights until it finally just gave out, i was riding around w/ the humming for about a month prior to that...
Vinalero 06-18-2007 11:36 AM
On my first bearing they were on for almost 4-5 monts before I heard a noise. On the second one they came on only a month after I was hearing the noise lol.
Vtolds 06-18-2007 11:48 AM
I would go ahead and jack your car up and see if you can shake the wheel. If it seems really loose (you shouldn't beable to move the tire back and forth normally) I would see you need a new bearing on that side.
Vinalero 06-18-2007 11:51 AM
What my meck did was just hold the spring with one hand and turn the wheel with the other, you could feel the bearing rubbing really well that way.
