-   LA1 3400 Specific (http://www.aleromod.com/forums/forumdisplay.php?f=19)
-   -   Alero Familia lol i need an answer (http://www.aleromod.com/forums/showthread.php?t=18583)
Exit9alero 07-27-2007 02:44 PM
hey guys would n e of you happen have pics or a how to guide to installing a vaccum and an air/fuel guages
a pick or what ever would do good
[ion] C2 07-27-2007 03:03 PM
google.com, instruction manual that comes with the gauge, etc. there's a lot of images, its real easy to do. also every gauge is different.
basically for the vaccuum you just tap off your FPR line, run the hose to the gauge. for the A/F one you run a wire to the engine bay and tap into the purple wire coming from your O2 sensor just above the exhaust manifold
Exit9alero 07-27-2007 04:33 PM
yeah i understand that the thing is i dont have the instructions but if anyone with a 3.4L engine and they could show me where to tap them off and idk a how too
Redog 07-27-2007 04:46 PM
I could give you a pic, but it's off my Delta, totally different setup, but it might give you the idea
rleach01 07-27-2007 09:23 PM
are there even any soft VAC lines? if so where at?
[ion] C2 07-27-2007 10:01 PM
just tee off the other one, simply add your tee to the end of the existing one, add your own tube from the other side of the tee to where the FPR hose went into the intake, and run the third hose off the tee to your gauge, easy as that
Cliff8928 07-28-2007 01:06 AM
On the 3400 you can just use that vacuum nipple that's capped off right by the alternator.
