-   LA1 3400 Specific (http://www.aleromod.com/forums/forumdisplay.php?f=19)
-   -   how hot is normal?? (http://www.aleromod.com/forums/showthread.php?t=18656)
Exit9alero 08-03-2007 02:21 PM
how hot is normal??
hey ive had this question for the longest whats the normal running temp on our v6 engines even after i got my lim done i noticed it was always above the half mark well into the 3/4 mark so im just curious and if it is a problem what should i do
doubleN0alero 08-03-2007 02:31 PM
i'd worry when its gets over the 3/4th mark..mine ran between those intervals as well...wouldn't be a bad thing to check out the antifreeze while you've got some time and just make sure its good to go
AGT 08-03-2007 02:39 PM
Mine ran this way as well. This is not so much of a problem until you are in traffic.
Exit9alero 08-03-2007 02:50 PM
soo high temps are a common issue with the v6 huh ive noticed like hate waves comming from under my car wen i have the windows down in traffic
p1mptress 08-03-2007 02:57 PM
my v6 always stays at half or a little below.
leroBob 08-03-2007 03:00 PM
min runs hott usully not quite at the 3/4 mark
Exit9alero 08-03-2007 03:04 PM
jea thas y im curious if theres an issue i believe they shud run at middle line but idk any more feedback?
rustyballs_69 08-03-2007 05:49 PM
Mine runs right at the half mark and its hot as hell here.
-Alero- 08-03-2007 06:20 PM
mine does not go past the half way mark ever.....only because i dont let it, because i got this!
http://www.pfyc.com/pc/GN3003/GAUNDE...an+Switch.html
it may be 90$ but it was worth it mainly because it spins the fans whenever you want and dissapates heat efficiently
SIUlero 08-03-2007 10:11 PM
From what I've read in another thread, our temp gauges aren't the most accurate. Mine sits right in the middle, but others are above or below that by a little or a lot. Best thing to do is learn where it usually reads and use that as a baseline to determine if you're heating up too much.
rustyballs_69 08-03-2007 11:08 PM
I know the fuel gauge aren't accurate!
jayson_waltz 08-03-2007 11:25 PM
^ no crap, i run with the low fuel light on for 2 weeks.
tonyboi261 08-03-2007 11:26 PM
know matter how hot or cold it is or how far ive driven mine always stays at the middle mark
rustyballs_69 08-03-2007 11:29 PM
I would get a new temp sensor, they are like 10 bucks a checker.
rustyballs_69 08-03-2007 11:30 PM
I ran out of gas but it said i had 1/4 of a tank.
Redog 08-03-2007 11:48 PM
Mine hangs out between 1/4 and 1/2. Right in the middle, but I do have a 180* thermo in there too.
It will creep up just under 1/2 when it's 95+ and really humid and I'm cruising
CiscoPath 08-04-2007 11:58 AM
^^Ditto. Installed the 180 thermo and it actually sits directly below the middle tick mark. If it goes even the slightest bit over (during normal driving; no heavy traffic), I add more freeze
01silveralero 08-10-2007 12:04 AM
lol i havent had that problem with either of my aleros. i get like 30 miles after the low fuel warning light comes on.
01silveralero 08-10-2007 12:05 AM
mine used to 3 years ago i dont know what happened though.
01silveralero 08-10-2007 12:07 AM
my i4 runs like 15 degrees below middle i checked with a obd-2 scanner my v6now runs at middle or little above middle with 180 thermostat.
