Change handbrake unit
I need to change my handbrake unit cause the raster function is not working anymore. I already got a new unit here, but:
How the hell do I remove the middle console...? I need to remove the shift knob to get the console out, but how do you remove it...???? :huh: |
just carfully pry it off with a flat head screw driver or something, its really easy.
if you need to remove the stock shift knob (if you have an automatic) theres a staple like pin in the back of it you will have to take out first, again a small flat head will work just fine |
Yes, I saw in the front of the (automatic) knob a little metal clip, I tried to push it with a screwdriver, but nothing happened. Does it need to be pushed?
Is it some kind of clamp or bolt...? |
the clip looks like a little staple... it pulls straight out.
OK, shift knob's no longer the problem.
What the fu** are those screws which holds the shift unit...???? :mad2: Seems to be a kind of TORX but nothing fits :( I'm not able to get any tool adapter here in Germany which fits for them .... I think I have to go the next Chevi Dealer to get this stupid handbrake unit changed.... Anyone an idea? |
get a pic of what your talking about
1 Attachment(s)
Here:
Attachment 2640 |
That's a tamper-proof Torx. You either need to get the correct bit with the hole in the middle of it, drill a hole in the middle of a regular bit or grind that little nub off in the middle of the head of the screw.
I've tried 3 different sizes of that TORX bit with the hole in the middle, bought it here in Germany (where else :)) but none of them fit :(
Seems to be an american size, maybe not metric? |
Torx don't come in metric or SAE...only T-xx, where xx is the size. Maybe you're missing that size
You could always drill it out
Yeah but I'm not very keen on drilling the hole out of the screw...
I found a bit set with nearly all sizes in it for less price at an online shop. I will order it and then try again get this stupid thing out... Thanks so far! |
good luck man
OK, it wont work. I've received the tool bit set and none of the tamper proof torx bits fit into these screws. :banghead:
I think I'll just drive to the Chevi dealer next week and let them change the hole unit....will be the easiest way. Big thanx too all for the help. |
