-   -   Blown Fuse (http://www.aleromod.com/forums/showthread.php?t=18853)
trumpetplayer91372 08-23-2007 08:04 PM
Blown Fuse
I need help locating the fuse that is for the interior 12 volt power sockets like the cigarette lighter and the one on the passenger side, i believe they are on the same fuse. I seemed to have blown mine becuase I am not able to power anything from either socket. I looked at the two fuse panels inside the car and checked a few fuses that I thought might be the problem, but none of them looked bad. Does anyone know which fuse is for the two power outlets or if there is another reason that the outlets would stop working what would i need to fix?
TheEdgeofSanity 08-23-2007 08:41 PM
i don't know offhand, but your manual should say or the inside of the fuse panel cover on the drivers side might say...that's where u want to start...mine don't work either and my fuse is fine so let me know what u find.
teflone 08-23-2007 09:14 PM
Theres some on the passenger side too..
And the one under the hood.. thats the one your interested in for your problem
trumpetplayer91372 08-23-2007 09:46 PM
yea as i said in my 1st post i checked those 2 side panels and either they were not the right ones or they were worded in a way i didn't understand. I haven't checked the one under the hood though, so i'll look into that tomorrow.
jayson_waltz 08-23-2007 10:05 PM
i know almost for sure that it is under the hood. just look at the chart on the bottom of the lid.
megabyte 08-23-2007 10:13 PM
yeah the fuse for the cig lighter is under the hood.
trumpetplayer91372 08-23-2007 10:35 PM
alright, thanks guys, ill check it out tomorrow since its pouring rain out here, hopefully it will be just an easy fuse replacement
Satsuriku 08-24-2007 12:08 AM
ya it is for under the hood cause i did the same thing when i installed my wheel well lights and i accidently crossed some wires and blow a couple of those fuses. it will be labled as cig light or something like that, really hard to miss it if you know what your looking for
AftermathAlero 08-24-2007 12:57 AM
#33 or #34 under the hood fuse box. it should be a 30amp fuse i believe or 25 or 20.. LOL been a long time since i've replaced mine.
trumpetplayer91372 08-24-2007 04:45 PM
Thanks to everyone that helped out, it was #34 a 20amp fuse located under the hood. I just figured it would have been one of the ones in the interior panels and never went far enough to look under the hood. Thanks for your help.
