HeadLight Trouble.
Hey. My driver side headlight is Messed. K well the running light doesnt turn on but if i hit it it will turn on. Thought it would be a loose connection and i pluged it in and out and still doesnt turn on auto Gotta do it manually and get out side my car and give it a little tap. Been haseld by the cops alot saying if they see it agin they mostlikly will give me a ticket. UNNO. but could the bulb be Dieing, Bad Bulb? What could be bee? bad wire? Just wondering if anyone out thier could help
thank you |
If you gotta give it a little tap to get it working, then there has to be a lose connection somewhere. take the headlight right out, check all the wires inside the light housing itself, try swapping bulbs.
i'd definitely go with swapping the bulb from the other side. As long as it works, it'll let you know if its the bulb, or the harness thats bad.
If its on constant when you swap, then its the bulb. If you still need to tap it, its the harness. |
thx Guys Im Liking this site i found since i got my alero!!! (Y)
