-   -   door unlock? (http://www.aleromod.com/forums/showthread.php?t=19056)
rleach01 09-07-2007 09:21 PM
door unlock?
i have a issue my drivers door will not unlock with my keyless entry on when i turn my car off, but it will lock just fine, i think if this is not an easy fix im just giving up(j/k)any ideas?
teflone 09-07-2007 09:26 PM
connector rod inside door panel is off or broken
Its bent or broken..
take door panel off, look for signs of something..
the fact it moves at all is a good thing..
Steven01 09-08-2007 12:07 AM
HA i had the same problem with my passanger BUT I NEW what happend. You see I locked my keys in my car few weeks back. and i only had the 1 key at the time. Soo I polled out the old coat hanger. And in like 2 mins i got it unlocked BUT i disconected the rod. And i just fixed this problem 2 days ago befor i got my comand start. open the panel and the rod was poped righr off the top click Kinda tight spot but yea. Open it up check
rleach01 09-08-2007 12:08 AM
but it unlocks just fine same problem?
SIUlero 09-08-2007 12:49 AM
does it unlock when you just hit the button on the door? also, does your pass door unlock when it should?
rleach01 09-08-2007 10:41 AM
sorry about the mess up on the last post my driver door dose not unlock when i hit the boutton on turn my car off but it locks just fine all other doors work fine like they should
Cliff8928 09-08-2007 02:58 PM
Check your driver door unlock relay in the drivers side electrical center (fuse box).
SIUlero 09-08-2007 07:45 PM
just got back online, but yeah...what cliff said. swap that relay with the other unlock relay or the lock relay....if it works, replace the bad relay
rleach01 09-08-2007 09:04 PM
ok that sounds good i opened the door up and everything was together, now can i switch it with any realy of the same size like and fuse?
SIUlero 09-09-2007 01:06 AM
yeah, I just mentioned the ones for the door cause they're right next to it
StoopidAlero 09-13-2007 12:06 AM
Hey.. Its definately the relay.. You gotta get the relay from an auto parts store.. Its a 3413 relay. GP Sorensen makes these from autozone and the part number is 41-5100
Easy fix.. Brandon
rleach01 09-13-2007 05:20 PM
it was the relay thanks for the help guys
