the big 3 mod
while reading the thread that jayson_waltz posted on if he needed a capacitor, i decided to do some research on "the big 3" that ryan from ohio mentioned on that thread. i did my research and i found this on another forum for the big 3. i just want to see if this is correct.
The Big 3 Are: 1. negative battery wire to ground - just replace the negative batt. terminal and wire and ground it to the factory location 2. engine block to ground - replace the ground wire from the engine block to the chasie with a bigger wire (maybe 4 guage) 3. alternator to batt - add a fused wire from the postive post on you alternator (the one comming from the battery) to the postive terminal on your battery. DO NOT exchange wires just add a extra one. make sure it fused the same size as your factory fuse. hope thats helps Note on #2- Some cars have a batt-engine block connection stead of chassis to engine block... and here is an image: ![]() is this correct? |
Thats it...
The wire for the engine block usually goes from the transmission to the frame. Its right in front on most GM V6's. |
What's the purpose of this?
bigger wires carry more amps with less voltage drop, so you get a more reliable electrical system and less load on the alternator and battery
oh ok. so the connector from the engine block is in front, but where exactly? what do i have to look for? and for the battery to ground: do i leave the original one on and add the 4 guage to the chasis or what do i do?
Im learning all about this in my electrical class. |
i thought you dropped? returned your tools and everything. |
