-   LA1 3400 Specific (http://www.aleromod.com/forums/forumdisplay.php?f=19)
-   -   Best Supercharger? (http://www.aleromod.com/forums/showthread.php?t=19530)
volfenhag_alero 10-12-2007 09:40 PM
Best Supercharger?
I would like to know what is the best supercharger for the 3.4L. I've got all of the modifications needed to run a supercharger with a decent amount of boost. I was looking at the RSM Racing Supercharger Kit, but all I've heard is negative feedback on that system.
[ion] C2 10-12-2007 09:44 PM
none are good that are available for the 3400, do a turbo
rustyballs_69 10-12-2007 10:30 PM
I bet kwhauck would disagree with that.
[ion] C2 10-12-2007 11:04 PM
i knew someone would say such a thing, however realize i wrote "that are AVAILABLE"
his supercharger was one of very few made, and none that i know of are still readily available
rustyballs_69 10-12-2007 11:11 PM
Very true, no one makes shit for the 3400. kwhauck got lucky to get one from the factory. I have looked everywhere for one and haven't had any luck. I think there were only like 16 3400's made with the supercharger. Im sure GM employees own the rest of them.
cherrington17 10-12-2007 11:18 PM
i'm sure with some fabrication, something could be lifted out of another engine. but the problem is how much work are you willing to do to get it to fit....
anything can fit anything. its just the (fab time+money)/(willpower + determination) equation you gotta figure out.
rustyballs_69 10-12-2007 11:21 PM
Fitting it in isn't the problem, The sell superchagers for the 3.4l that came in the S-10s. Its all the tuning that is the hard part or the costly part.
Spilner521 10-13-2007 03:48 PM
Nah, tuning is easy depending on what kind of fuel mods you pick, especially with a supercharger when there will always be the same amount of boost/airflow at a given RPM.
volfenhag_alero 10-13-2007 08:16 PM
I got new heads, valves, pushrods, supercharger ready cam shaft(stage 2), Stage 3 Upper Intake Manifold, Stage 3 Lower Intake manifold, S&S Headers, New PCM Tuned for a Supercharger and Nitrous, Spark Plug Wires and Platinum 2 Spark Plugs. The RSM Supercharger is just about right for my set up and I'm pretty sure I will be able to run about 13-15lbs. of boost.
rustyballs_69 10-13-2007 09:21 PM
Im sure it is easy for someone who has done it before.
[ion] C2 10-13-2007 09:29 PM
and you forgot forged pistons and rods? good luck with 15 PSI
volfenhag_alero 10-13-2007 10:15 PM
I already upgraded my pistons and rods and my fuel system.
[ion] C2 10-13-2007 10:29 PM
sounds like you're all set, why supercharge for the enormous price RSM offers, plus negative reviews, when you can do a turbo setup for far cheaper? talk to BJ!
jabartram 10-13-2007 11:09 PM
you would be better off turbo'd, you have endless possibilities. with a s/c you are limited.
YALEROYNOT 10-14-2007 12:14 AM
links for a turbo kit for the 3400 ?
Spilner521 10-14-2007 01:34 PM
It's easy if you understand how the whole system works and how your fuel system is setup, which honestly you should understand fully if you're going to build and/or tune your own kit.
Spilner521 10-14-2007 01:36 PM
I agree.
rustyballs_69 10-14-2007 02:23 PM
If I ever get to that point with my car Im sure I would learn to do it. No point in paying someone when you can do it yourself.
jabartram 10-14-2007 02:55 PM
i tune constantly at this point, i make small changes drive for a couple days to let trims settle, and tune again, so that when i get my turbo kit, i'll be mentally prepared for what i need to do.
its amazing what tuning can do for power, each car is different, i was still in VE-Tune stage when my friends Mazda 6 couldnt leave me, now i'm working on maf-tune, then timing so on and so on.
alerored04 10-14-2007 10:43 PM
I want pics of this build. And who sells "stages" for intake manis?
