Fog Light Question
Ok, so this might be an odd question, but are all alero fogs the bottom feed style projector? For the bulb? Cause I know this type of projector was also a rear feed bulb style, which I'm looking for.
Yep they're all the same, the bulb enters the projector housing from the bottom. You can get mini projectors to replace the stock fog projectors with. They look like this:
![]() You can get them here: http://www.hidplanet.com/halogen.html They may even fit into the shroud that the stock projectors show through. Only thing is you'll need to switch connectors to run a H3 bulb instead of the 894. |
Blah, its mainly that the blazer fogs (which our cars have stock) are really good for switching over to hid..... but apparently the bottom feed wont work with it, only the rear feed :(
