-   Alero Show & Straveganza (http://www.aleromod.com/forums/forumdisplay.php?f=38)
-   -   If I Go To Ass Is There A Possibility? (http://www.aleromod.com/forums/showthread.php?t=20992)
Jferg2223 02-12-2008 10:33 AM
I am not to into the tuning thing so i dont know much about it..........but......... can you use your tuner on someone elses car? If so if i show up to ASS is there a possibility that somebody can delete my O2 codes and give me an update. Maybe change a VIN number for me or something.
[ion] C2 02-12-2008 10:45 AM
Lol.. if they know how to use HPTuners, it does cost a certain amount to use it on each car you tune, but to change a VIN number, not sure on that one... o_O...
paulyb 02-12-2008 12:55 PM
why would you change your vin number?
misslindseysue 02-12-2008 01:02 PM
Autozone or anyone with an OBDII tool can clear codes. I can program VINs in Hyundais and Kias, but I stay away from that, due to the fact that changing them is against the law. If you have a legit reason to change a VIN, go to a dealer. They have to have the tool that does it in case they change an ECU or something that has a VIN programmed.
Jferg2223 02-12-2008 03:46 PM
^im not clearing codes..................I am deleting them from my pcm. The PCM I have now is not from my car, I still have my stock PCM but this one is a DHP from a grand am.
jackal2000 02-12-2008 04:12 PM
what year is your car? i'll bring my powrtuner and we can see if i can do it.
Redog 02-12-2008 10:02 PM
That's a good reason, if you needed another PCM.
Call you're local dealer
Jferg2223 02-13-2008 11:05 PM
jackal my car is a 2000, I am just trying to see how minimal I can go, Im buying headers but i dont want o2 bungs, I will go 2.5" mandrel and redo my dual layout. I am going with a dynomax straight through muffler where the resonator normally is and then y-pipe after gas tank then break off the y to my duals and I dont want any restructions. Plus this PCM i have keeps throwing the O2 codes but i have replaced both of the sensors and it did the same thing when my buddy had it in his grand am so if i delete the codes all together I wont throw the ses light.
jabartram 02-13-2008 11:24 PM
if you go to your dealer with a pcm from another car, say a junkyard pcm, they will only change the vin if it is programmed with the oem software for that car, so a dealer is a bad idea.
MilzyZ34 02-13-2008 11:27 PM
DHP tends to lock their PCM's, you may be out of luck.
I can flash your stock computer for whatever you want, but not the other if it's locked.
jackal2000 02-13-2008 11:50 PM
my car is a 2000 as well. i dont think its a good idea to go totally o2'less. i deleted the codes for my downstream since i dont have one but i still run the upstream (pre-cat) sensor.
Jferg2223 02-14-2008 12:36 PM
I can handle That^
jackal2000 02-14-2008 12:38 PM
i guess thats incentive for you to come to ASS then. chances are good i can fix your pcm.
Jferg2223 02-14-2008 12:38 PM
i know you CAN but the point is im buying a house right now and just flat out of money for now. So if someone with hp tuners can just help with a couple things that will work out for me. The vin issue really isnt that big of a deal just want atleast one O2 gone.
Jferg2223 02-14-2008 12:39 PM
yeah jackal i will definately be there but im gonna wait to redo my exhaust until after ASS.
