Wiring Diagram
I have a remote start/alarm that i would like to install in my 2004 Alero. I was wonderin if anybody can tell me where to get the wiring diagram.
well you could always buy a haynes manual
I have one. I was looking for a colored one. |
I would use Bulldogsecurity.com if I was you. Very helpful information. Also there is a sticky in the general perfomance thread with a link to where you can find out about the wiring to your car. Between the two of these I installed mine with no problem.
I finally finished un-"rigging" my remote start a few seconds ago. :) The haynes manual is a great buy if you ask me. First off you're going to need to order a GM-6 Harness if you wan't the remote start install to be smooth. You'll also need to familiarize yourself with passlock, how it works, and why you want to bypass it. Take a look http://www.aleromod.com/forums/showthread.php?t=20698 and http://www.aleromod.com/forums/showt...ighlight=alarm Catch me on msn messenger at goldstar611 @ hot mail.com as well.
Can you explain the GM-6 Harness. I have looked all over for the hrness. All th sites says it is discontued (sp) |
bascially, you unplug the wires from the ignition, plug into GM-6 harness, and plug other end back into ignition. The harness has tapped into all the necessary wires, you just need to connect everything up with crimp connectors and you're set.
