HID's?
Hey I bought some Xentec HID's and I got them working but how can you put back the rubber circle that covers the headlight hole, there are wires running out of it. Do you need to drill a hole through it or something?
make a little notch on the edge before you stuff the cover on, works fine to run wires through there.
Also just after I installed them my Service Engine Light came on.
Your engine light has nothing to do with headlights, it was just a coincidence.
So it it okay to drive around without the rubber circle grommet on the back of the headlight?
No, it will let moisture in. Cut a hole in them and put them back on. |
