-   -   Help with CF Bezel (http://www.aleromod.com/forums/showthread.php?t=21376)
[ion] C2 03-09-2008 01:44 PM
Help with CF Bezel
So how exactly do I remove the clear plastic cover from the black plastic housing that goes over the gauge system so I can put the carbon fiber gauge bezel on?
It appears to be melted together or something. Don't want to pry on it in fear of cracking.
adam337 03-09-2008 02:41 PM
you need to use a dremel. then when you put the bezel in use clear silicone to put the plastic back on
[ion] C2 03-09-2008 02:44 PM
lame.
CBLOHM3400 03-09-2008 03:50 PM
C2 i put mine in with out cutting anything
from the back side of the clear glass housing thru one of the holes that the tach or speedometer it will fit with a little patience
it is flexible enough to bend but not crease to fit in the hole
[ion] C2 03-09-2008 05:09 PM
yeah i was trying that at first then i gave up
Marrko 03-09-2008 05:22 PM
i tried to take apart the clear lense without a dremel and cracked it.... now looking for a new one :(
[ion] C2 03-09-2008 06:13 PM
got it in by fitting it through the tach hole, wasn't hard at all lol:
Mischief007 03-09-2008 06:52 PM
That looks good.
14alero 03-09-2008 07:43 PM
So it doesnt have the plastic peice on it anymore
[ion] C2 03-10-2008 08:43 AM
the carbon fiber is an overlay, the plastic bezel is still there, under it
nickbain 03-10-2008 09:19 AM
i like it, where did you get it at?
[ion] C2 03-10-2008 09:33 AM
eBay, they pop up every once in a while
Trickyslick 03-10-2008 10:14 AM
Looks nice. Good Job.
TheMeaningOfLife 03-10-2008 11:05 AM
I want one... looks nice to!
AlbinoMonkeyRat 03-10-2008 11:29 AM
to all those that are going to get it:
I had it. if you do indeed get it, make sure you protect your car from heat. mine craked in 3 places because of the excessive heat in the summer time. I loved the look of it when I had it, but I never felt motivated enough to buy another one. LOL
natedawg9640 03-10-2008 05:59 PM
is that actual carbon fiber? or is it printed? and how much was it?
