-   Audio, Video & Security (http://www.aleromod.com/forums/forumdisplay.php?f=16)
-   -   Would this be overkill? (http://www.aleromod.com/forums/showthread.php?t=2157)
vodkaslut85 05-05-2004 08:35 PM
Hey guys, I bought my friend's infinity Kappa 10.1 10 inch sub off of him for 100 bux, they retail for 250 brand new and this one is still in box and never been wired to an amp...the wattage rating for this sub is 100-400 watts RMS and 1200 watts Max, I found a cheap MA audio amp on e-bay for 170, 195 with shipping that puts out 600 Watts RMS at 4 ohms, the same as the sub, do you think this would be overkill for the sub or would it sound fine and shoud I just set the amp's power level a little lower?
Purple&Black 05-05-2004 08:40 PM
I say do what you said. You shouldn't really get much distortion from the amp running it at 67% like that. Unless you want to look for a 500 watt amp from a different manufacturer that might perform better or has more features (didn't look to see what the amp you mentioned does) for the same amount of money. Just a thought. But you're on the right track...avoid underpowering the sub.
vodkaslut85 05-05-2004 08:45 PM
here's the link to the amp on e-bay :MA Audio amp
*edit: here's the link to the sub's page on crutchfield, and it's 1400 WAtt's max, link
BLK03GXS 05-05-2004 08:50 PM
IF its an MA audio amp, most likely its rated at 14.4 or more volts.. i wouldnt hesitate to run the sub offa that amp, should be ok, just be carefull and make sure that you dont blow it with too much boost.. and i would recomend using it in a sealed box, as sealed has the the best power handeling propertys.
Steve03TropicTeal 05-06-2004 08:59 PM
def runned a sealed box.
As far as power, it may be very easy to blow that, That is a killer amp.
Blowing is definately possible. Keep the gain low. Youll know the distortion when you hear it.
BLK03GXS 05-06-2004 10:54 PM
Whats the model # on the amp...
From my experance with MA audio's stuff... it is overrated like all the other junk out their....
havik 05-07-2004 10:03 AM
Infinity underrates their subs as well
BLK03GXS 05-07-2004 05:07 PM
Right.... so with a amp that prolly puts out 600watts rms at 14+volts... runing in a car the amp should be a good match for that sub im a sealed box
xsavyor1 05-09-2004 06:22 PM
Ma Is ok but there power rating are based off of a 16 volt system.
BLK03GXS 05-11-2004 05:34 PM
Thats basicly what i was saying...lol
