-   LA1 3400 Specific (http://www.aleromod.com/forums/forumdisplay.php?f=19)
-   -   raise idle? (http://www.aleromod.com/forums/showthread.php?t=21904)
JOEY GLADSTONE 04-22-2008 09:33 AM
raise idle?
ive been having voltage problems with my car and if i could raise the idle about 150rpm it would fix everything, my engine doesn't seem to idle at the right RPMs because the whole engine like shakes at idle and i was just wondering if theres anyway to change the idling RPMs since everything on the TB is automatic
[ion] C2 04-22-2008 09:41 AM
besides the throttle body idle set screw
screw it in slightly, it pushes the butterfly open
JOEY GLADSTONE 04-22-2008 09:44 AM
i dont think that it has an adjustable screw on it, i think its just something crimped onto the end of the throttle cable
[ion] C2 04-22-2008 10:12 AM
super white alero1 04-22-2008 01:49 PM
you should first try to clean the IAC valve A black valve located on the throttle. That's the normal case of surging idle.
