-   Audio, Video & Security (http://www.aleromod.com/forums/forumdisplay.php?f=16)
-   -   Started my fiberglass trunk (http://www.aleromod.com/forums/showthread.php?t=21926)
bizarre179 04-23-2008 01:56 AM
I started making my fiberglass enclosure for my trunk today. It is 3 pieces, so I can easily remove it from the trunk if needed. Then there will be a fiberglass cover to go over the whole thing to make it look like one piece.
Here is what I got so far...
I still got some kinks to work out, like the trunk hinges being in the way, but besides that there isn't too much else. It fits perfect and hopefully still will when it gets glassed.
I will be adding more pictures as I go along.
Just noticed this... the timestamp is WAY off. I really just did this.
huskeyeskimo 04-23-2008 08:33 AM
Looks like a great design for a box. How is it your splitting it into 3 pieces? Def keep pics updated. Can't wait to see how it turns out.
YALEROYNOT 04-23-2008 08:42 AM
looks good
don't you want to have the speaker rings cut out before glassing them ?
Trickyslick 04-23-2008 10:17 AM
Great start and take picts during the process so we can see its transformation.
bizarre179 04-23-2008 12:43 PM
Originally Posted by huskeyeskimo (Post 351348)
Looks like a great design for a box. How is it your splitting it into 3 pieces? ...
The wheel well pieces that hold the amps are separate from the middle section. I will glass them at the same height so they look like the same. Then, I am just going to fiberglass a cover over it so it all looks like one piece.
Originally Posted by YALEROYNOT (Post 351350)
looks good
I saw someone else do it this way... so i decided to try it. But i am not sure if I wanna do it like that. It probably would be easier to cut them now instead of doing it when it has multiple layers of glass on it.
lonnie 04-23-2008 12:43 PM
Looking good
paulyb 04-23-2008 01:55 PM
looks good so far, keep up the good work and updates.....
bizarre179 04-25-2008 12:03 PM
Ok, so I got the enclosure glued down and wrapped with fleece last night and couldn't resist to start fiberglassing. Now I just got done with my 2nd coat of glass and it seems to be coming out good.
And with fiberglass...
This has been a pain to get to fit right in my trunk. The only problem that I am facing now is the side amp pieces. I got them looking the way I want, but when I went to fit it, the trunk hinges hit on one side. So after a couple hours of tweaking, I got them to fit a way I like but know I dont know how I am going to fiberglass them. I am thinking about just wrapping them in fleece them making a piece to fit over them cosmetically and just reinforce them with wood underneath.
I was so pissed last night that I even thought about getting actuators to lift my trunk straight up. Talk about building a car around the stereo... It still seems like a cool idea and I know it would work fairly good but right now I dont even have money for another gallon of fiberglass...
So thats where the project stand at the moment. I cant wait till its done!:yahoo:
Oh and please, someone tell me that the trunk is the same on a 4 dr as it is on a 2...
TheMeaningOfLife 04-25-2008 12:06 PM
if you cut the tops off the "tubs" for the amps it would still look okay and the amps will kinda cover it up aaannd it migt solve you hinge issue.
bizarre179 04-25-2008 12:25 PM
You are right. I think I am going to do that. Thanks!
TheMeaningOfLife 04-25-2008 12:34 PM
No problem, im intrested to see how this goes because ive always wanted to do this.
bizarre179 04-25-2008 12:51 PM
Same... and since someone talked me out of building a boxc for my backseat... I wanted to do something just as big.
I have too many projects going on... this trunk project, custom tails, projectors, switch panel... err TOO MANY!
TheMeaningOfLife 04-25-2008 01:32 PM
Yeah better than me, i dont have enough, but some need to be done. haha
