New...but i've been here before
Im new as a member but i come here a lot for random stuff that i need to look up. I have a Red 2003 GLS with under 30k miles that I've owned since November. It has 5% tint in back three windows from Notorious Tintz in Livoina done by the owner who said it was the cleanest alero that he's ever seen (i had 15% up front till i got a ticket and had to take them off), Just Replaced the stock GoodYear RS-A's with some new Raptors on the Chrome 16's less than 20 Miles ago, I'm bout to drop in my 12" Kenwood with boston acoustics amp when ever i figure out how much wire I'm gonna to need to do the Job, Also upgrading to bigger chrome dual tip (slanted up) muffler and i'll most likely end up doing a bigger exhaust haven't decided yet on that tho. I wanna lower it a few inches but its a tough choice with the Michigan winters and horrible roads they leave behind. And im also looking to put on the chrome mesh grill. Well thats about it for the newb introduction lol.
*P.S. if any one wants to fill me in on the most user friendly way to do the clear corners* *or if anyone knows the most direct way to go about installing a sub so the wires wont show, then hit me up* -Joe |
Welcome. your car look orange in that avitar.
Clear corners thread are a dime a dozen. Use the search button and I'm sure you'll find them. It's not really that hard to do ;) |
if u are ever in dearborn stand clear of this alero
![]() :p u have like the first alero i seen that is that color |
Welcome and Happy Modding...use the serch button for a how to clear corners...I still need to do mine.
Heres the thread to show you step by step... http://www.aleromod.com/forums/showthread.php?t=10 |
Its actually not that orange it's that rare candy red that you hardly ever see. I've only seen it on one other alero and it was out of state.
welcome.
indeed |
Welcome aboard!
easy way to hide wires? power wire through the gray grommet slightly above, and to the left of the brake pedal, then run down the drivers side (next to the seat and behind the backseat paneling) then run the RCAs down the other side. i put a small slit in the carpet in the center console so i could slide the wires straight down under the carpet w/o being seen, but basically hid the same way.
Welcome to the forums, LiveWire. :) *** |
