-   -   is it possible? (http://www.aleromod.com/forums/showthread.php?t=22589)
bigdaddyD 06-09-2008 05:22 PM
is it possible?
i was thinking, i know alot of guys like to turbo their cars alot of guys like the SC option. So i was wondering would it be possible to have the best of both worlds? have a SC feed into the turbo? If so, would it reduce the "Turbo Lag" that turbos tend to suffer from?
super white alero1 06-09-2008 05:28 PM
I heard rice saying they have a SC and a turbo before and i smirk. But to come and flat out ask does anyone have both setup on 1 car is unique. I never seen both on 1 car so I say no.
-Alero- 06-09-2008 05:30 PM
yes and yes.................turbo option would be a dual turbo setup known as Bi- turbo, one small for quick spool, one large that overtakes the small for higher rpms
there are plenty of ion redlines and cobalt SS's with stock superchargers and aftermarket turbo's......."twin charged" if you will..........also i believe there is a grandprix wit hthe L67 (stock supercharged) with a big turbo
and to answer you other question yes it eliminates lag, because SC is instant, and where the SC falls on its face turbo picks up..... so it can be done all it takes is money.......and a little bit of time
LiveWire 06-09-2008 06:55 PM
oh that would be sick.
natedawg9640 06-09-2008 07:16 PM
if my memory serves correctly maseratis made a name for themselves in the bi-turbo world. i've seen cars with supercharged superchargers... and most definately twin charging is possible...
twin superchargers
http://www.youtube.com/watch?v=kiWUN...eature=related
twin charged
http://www.youtube.com/watch?v=brZ0B...eature=related
http://www.turbomagazine.com/feature...ged/index.html
here's this car http://www.youtube.com/watch?v=rd4XA8czlks
[ion] C2 06-09-2008 07:25 PM
Yes of course it's possible. The best setup is to have the turbo bypass the supercharger completely once it's spooled to eliminate any flow restriction the supercharger might cause.
There's a twincharged j-body that made 240whp on 7 PSI, and 248whp on 11 psi with just the turbo. it's far more efficient to twincharge, and you get the supercharger whine, turbo whistle and blow off valve sounds all together
-Alero- 06-09-2008 07:34 PM
^^ lol what more could you ask for in life
Cliff8928 06-10-2008 01:52 AM
This has got to be my favorite twin-charged setup..
16v Volvo 2.3 with a GT40 and M62 churning out 578HP and 505 Ft-lbs!
The car (Opel Manta) runs a 10.52
Redog 06-10-2008 07:07 AM
Those Volvo motors are underestmated. They can make some crazy power :eek:
I think it could be done. It would all be in the programming ;)
1TONK5 06-10-2008 08:05 AM
Neato stuff. I believe it was some of the old Detroit diesels that were set up with the turbo feeding into a supercharger. We're talkin OLD big rig motors.
bigdaddyD 06-10-2008 11:19 AM
so what do you guys think would be better, SC+turbo or TT?
AJules 06-10-2008 12:05 PM
I'd go with 2 turbos.
Seems like it would be easier all around.
[ion] C2 06-10-2008 12:08 PM
yes it would, tuning for twincharging and doing a twincharger setup properly is difficult
bigdaddyD 06-10-2008 12:12 PM
is there enough room under the hood for either setup without having to do any kind of major work(besides getting the setup to work)?
AlbinoMonkeyRat 06-10-2008 12:15 PM
on an alero, there would be enough room, but you have to be super good at mapping out the pipes to 1) make it all fit and 2) keep a smooth flow without sharp bends
AJules 06-10-2008 12:21 PM
Well this depends on which engine you have
If you have the 3400, you're gonna hafta move some things around
The battery is probably a good place to start
If you have one of the 4s, you have a little more room to work with.
bigdaddyD 06-10-2008 12:33 PM
ya i have the 3400, as far as moving the battery, is there a kit out there? also im assuming i would probably have to remove the air intake?
cherrington17 06-10-2008 12:59 PM
i still like the engine shot from a VW Golf, that a company built to beat the enzo in 0-60. i believe it was a twin turbo setup? (maybe its bi-turbo) eitther way, it has two beastly turbos and had what they said was "aggressive acceleration" :D
AJules 06-10-2008 03:26 PM
Could you post a picture?
I'd like to see that.
bigdaddyD 06-10-2008 03:41 PM
i think he is talking about post #8
