-   Audio, Video & Security (http://www.aleromod.com/forums/forumdisplay.php?f=16)
-   -   aftermarket stereo (http://www.aleromod.com/forums/showthread.php?t=23016)
chaimv 07-13-2008 03:38 PM
aftermarket stereo
Hi Guys
I tried searching teh forums but cant find what I am looking for
I have a 2001 Alero Base Model (GL I think) no keyless entry. I want to replace my factory radio with an aftermarket one. I have done this before on other cars what I dont know is what factory wires are what
The new steroo has 4 pairs that are marked for speakers and 3 additional wires . Which wires would i Splice them into on the factory wires
Thanks
Chaimv
kniedelm9490 07-13-2008 04:04 PM
spend 20 bucks and get the wire adapter that you'd need for your car. colors should match up.. goto best buy or abt or any audio place
bkathsalero 07-13-2008 05:00 PM
NEVER CUT THE STOCK WIRE HARNESS!! spend the extra 20 at wal-mart even, saves alot of time! and ull be thankfull later!!
Noseminer 07-13-2008 05:36 PM
Those harnesses should also be identified so you know which wires are which to save any confusion on your install.
chaimv 07-13-2008 06:07 PM
Thanks for the replies.
I tried looking for the adapter but have not been able to find one at bestbuy or walmart here in toronto, on .
If I choose to splice into the origional wire harness. I am not planning on cutting it off just attaching wires in the middle of the origional do you know which collor wire is what in the origional harness
thanks
chaimv
lonnie 07-13-2008 06:12 PM
Try circuit city then! or order online from crutchfield. Someone has it
Noseminer 07-13-2008 06:14 PM
Try Canadian tire for the harness or any stereo shop would haved one. That would probably be the easiest way to go. The harness would give you extra wire so you are not reaching into the dash to try and wire it up.
1TONK5 07-13-2008 08:13 PM
Harness shouldn't be too tough to find. Another thing to think about when you install the head unit is to run new speaker wire. It will be a good bit more work, but the results will be worth it. The stock wiring isn't all that great when you compare it to some aftermarket 14 or 16 gauge. Cutting up the factory harness (even if you are just splicing) is a hack way to go about things though...no matter what route you take.
Vtolds 07-13-2008 09:31 PM
I got mine at a little car customizing place. Specifically it was listed for the Grand Am of the same year.
jeenysrider07 07-13-2008 09:57 PM
do not cut the harness
lonnie 07-14-2008 07:14 AM
If you are buying a harness I don't see the need to rewire the speakers unless you are amplifing them. If you are just replacing the HU then I wouldn't rewire stock speakers.
zzyzzx 07-14-2008 09:11 AM
I agree 100%! Only a moron cuts the factory wires.
tw0123 07-14-2008 11:52 AM
If you are in Toronto, you could easily find one at Future Shop, 2001 Audio, or Best Buy, Walmart, Canadian Tire, or take a drive to find a little Car Audio Shop...There is one in Newmarket called Nosh Audio, they are decently priced, or Whitby HiFi on Hwy 2... if they don't have one, they could easily get it for you... I used one for a 2000 Cavalier in my car, same pins/wires etc. and it works great.
Ryan from Ohio 07-14-2008 01:00 PM
Even splicing into factory wiring isnt good. Thats list a last straw type of thing.
I would just order one online. Hacking into factory wiring of any type is rarely a good experience.
chaimv 07-14-2008 04:26 PM
Thank guys
I will try loking for the harness under similar gm models.
Thanks for the list of palces that they can be found
Chaimv
bkathsalero 07-14-2008 08:02 PM
By the way heres the info u wanted.. (for reference) on a 2001 olds alero
but remember the advice DONT CUT THE HARNESS
ok so the connector has a total of 24 pins (Outputs for wires)
the top row is considered row A (example: a9)
The bottom row is row B.. each row has twelve outputs..
Heres the order: (pin #, Wire color, Function)
A1, PPL, Class 2 Serial Data (Primary)
A2-5, Not Used
A6, Yel, Radio On Signal (Oldsmobile)
A7, LT Green, Remote Radi Control Signal (Oldsmobile)
A8, Tan, L/F Speaker +
A9, Gry, L/F Speaker -
A10, LT Blu, R/R Speaker -
A11 DK Blu, R/R Speaker +
A12 BLK/WHT, Ground
Next the bottom row, (B PINS)
B1, Orn, Battery Positive Voltage
B2, Not Used
B3, Dk Grn, Antenna Relay Coil Supply Voltage
B4, Gry, Instrument Panel Lamp Supply Voltage-1
B5, Blk, Ground
B6, PPL, Gain Control Signal
B7, Not Used
B8, Brn, L/R Speaker +
B9, Yel, L/R Speaker -
B10 Dk Grn, R/F Speaker -
B11, Lt Grn, R/F Speaker +
B12, Park Lamp Supply Voltage
