-   LA1 3400 Specific (http://www.aleromod.com/forums/forumdisplay.php?f=19)
-   -   What grade gas? (http://www.aleromod.com/forums/showthread.php?t=24627)
chubbyboy88 11-07-2008 09:24 AM
What grade gas?
I was wondering what grade of gas is best for my Alero?
doubleN0alero 11-07-2008 09:28 AM
87 works just fine unless you have significant engine mods that require a higher grade. I've found better mpg using 89, but thats just me and not to be the sworn by truth applying to everybody.
AGT 11-07-2008 09:38 AM
Mine always liked 103 octane. It ate it quicker so it must like it better :lol:
chubbyboy88 11-07-2008 09:48 AM
where do you ger 103 octane from?
AGT 11-07-2008 09:56 AM
track LOL
Honestly you won't need more than 87 or 89 if you are stock.
doubleN0alero 11-07-2008 10:03 AM
The better question is where to get a new engine if you run this...
chubbyboy88 11-07-2008 10:13 AM
lol so I have a stock Alero 3.4 with a k&n air filter but will be adding mods in the Spring.So for right now 87 or 89 is pretty much good but when I add on more mods I need to put 93.Why do I need to put a higher grade fuel when I put in the mods anyway?
doubleN0alero 11-07-2008 10:18 AM
Even with the mods, it won't require a higher octane. Jackal2000 did a DHP pcm upgrade which required him to jump to 93.
chubbyboy88 11-07-2008 10:26 AM
ok so I should only put higher octane if the mod says it requires it?
doubleN0alero 11-07-2008 10:29 AM
I think the DHP is about the only thing that requires it, so you should be good with the cheap stuff.
lonnie 11-07-2008 10:41 AM
You only need a higher octane gas if you have a higher compression engine.
[ion] C2 11-07-2008 10:46 AM
*if you're producing a lot of heat that may cause pre-ignition
undecided02 11-07-2008 09:18 PM
honestly if your engine doesnt require more than 87 octane than you wont notice any change at all. it is all based around compression, and if your engine doesent require a change of gasoline than its not worth the extra cash you would pay for it.
chubbyboy88 11-07-2008 10:12 PM
Does anybody know where i can get a dhp for cheap and a cold air intake?
cherrington17 11-07-2008 11:00 PM
you don't need DHP if your only running a CAI, don't waste your money. rebuild the engine, get headers and a full exhaust, then go dhp. won't do much till then.
cheap CAI, go to ebay.
