How to tune your amp!
I found this and thought it was SUPER helpful and interesting! It's how to properly tune your amp with a Multimeter!
So you're going to need.. the MM a 50hz test tone: http://www.bnoack.com/index.html?htt...downloads.html Burn your tone to a CD, mp3 player, etc. Then head out to your car. Unhook the woofers from the amp. Make sure your know what impedence you're running at the amp (2 ohm, 1 ohm, 2.66 ohm, etc), if you're not sure, disconnect the woofers, and use your MM on the ohms setting to measure the wires where they would plug into the amp (on the woofer side of course), and whatever you get, that's your impedance. Next it's time to do math. You're going to be using the equation P=(V^2)/R. P=watts, you pick the number, let's say you want 1000watts powering your subs. R=resistance.. or impedence, this is the ohm load your subs are wired at.. lets say 1 ohm on a monoblock amp V= voltage (AC), this is what you're going to be measuring in a second, but first you need to find what you're looking for So plug it in and solve 1000= (V^2)/1ohm... and get V = 31.6 V(ac) Now, fire up your audio system (woofers still unplugged), turn it up the loudest you plan on having it on any given day (volume and bass EQ), and play the 50hz test tone. Run back to your amp, set the multimeter on V(ac), and measure from the two outputs. Adjust your gain until you're at 31.6V. Woo! Now you'll be giving woofers on a 1ohm load exactly 1000watts. This works for any setup, just math it all out and then tune. Hope someone else found this interesting, just figured I'd share. |
That is very interesting. I should give it a try. Thanks!
Actually tossing a DMM on a set of speakers leads wont tell you what Ohms your running at. You are measuring DC Resistance at that point NOT AC impedance- which is what the amp will be seeing.
ah, quite mistaken then, how do you measure then?
You cant measure AC Impedance. Its an average.
Take a DMM put it to Ohm and hook it to the speaker. Push the cone slowly and watch what happens... |
Gee I seem to remember having written a "how to" on setting gains with a dmm... If I get some time later I'll put it up... There is also a "how to" for installing an amp that goes with it.
Oh I didn't search, so my bad if you already did!
Ryan, it will indeed vary, because as you move the cone the coil moves in the magnet and produces a voltage. |
Look at the quote a little bit closer... :lol: Dang old man. :lol: |
For those that don't understand the formula, this is the transposed version for voltage from the original posted formula by clutch.
V=SQRT(RMSwatts X speaker ohms) So my example is V= SQRT(600wattsX2ohms) V=SQRT(1200) V=34.64 So I need to see 34.64 volts out of the amp to reach 600 watts rms. |
This is a decent beginner way to set an amp, but defintly is not the best.
Sure, you are getting "x"rms at 50hz, but what about at other frequencies? Your impedance will change at every note. So basically what I'm saying is that doing this method, you can guarantee that your amp is still going to clip at a range of frequencies. The best way to do it is by ear. |
lol at myself... The truth is for most a dmm (digital multi-meter) is the best way to set an amp. While some like to do it by ear, the problem with bass is that many times you cannot hear the distortion (especially at 3/4 or more volume) and since most don't have the money for an oscilloscope a cheap $15 (or less) dmm can save you a lot of trouble and money down the road. |
