-   -   Pushrod Removal (http://www.aleromod.com/forums/showthread.php?t=26184)
Nate's Alero 03-07-2009 08:39 AM
Pushrod Removal
Well, im in the middle of my headgasket change, got a few questions answered by calling some amodders, but still, when i remove the valve covers, and i remove the rockers, do i need to write down the amount of turns it took to get the rockers off?
or do i just remove them and then put them back on snug? im confused... and i would like to pind a pushrod puller, but i cant seem to locate one at any local autoparts stores, becuase i would not have to remove alll these pumps and screws / harnesses,
please help?
Ryan from Ohio 03-07-2009 08:46 AM
This the V6?
Mine wasnt adjustable. YOu just take the bolt off and it lifts out. Same with push rods. I didnt take the "hydraulic" part out.
Nate's Alero 03-07-2009 08:54 AM
Originally Posted by Ryan from Ohio (Post 438797)
This the V6?
yeah, just taking the rocker and rod out....
another question, on the alternator feed line, there are two bolts, the bottom one, then where the feed wire sits and then the top bolt, now, i accedentaly made the bottom bolt loose, and now have to use two wrenches to hld the bottom bolt still while i loosen the top one, plz help?
AND HOW THE HELL DID YOU GET TO THE BOTTOM COILPACK BOLTS!?!?!?!?
Nate's Alero 03-07-2009 10:58 AM
bump, still need the help
alerored04 03-07-2009 11:08 AM
The bottom coilpacks need a long extension a wobble joint and a deep well socket. The alt is fine, just hold the bottom nut while taking the top one off so you can remove the wire. Be sure to slip the cover back over it when it is off since it is still hot if the battery is hooked up. There is no such thing as a "pushrod puller" you simply unbolt the rockers and remove the pushrods, make sure not to mix them up or you will trash your motor. The rockers can be mixed and matched so you can just throw them in a pile. The tab on the pedastal of the rockers makes them self aligning, all you need to do is torque them to the proper spec and preload. Which I believe is 18 ft/lbs + 90 degrees but I may be wrong so check that before you use it. I dont have my haynes manual with me to find out for sure. Hope that is what you were looking for.
Nate's Alero 03-07-2009 11:22 AM
do you have a phonenumber i can call you at? PM me it and ill PM you mine, it will just help for a quicker response,
and i figured out that the alt is still hot when it is hooked up... LOLZAP i got it good, good thing the battery is really dead (so much it wont play the radio)
there is a pushrod puller, but im not waiting to order it, and no one around here has it
cherrington17 03-07-2009 11:23 AM
battery wouldn't have anything to do with that... :lol:
Nate's Alero 03-07-2009 11:24 AM
no, its the main wire to the battery, it was still connected when i was unscrewing the hot line in the middle of the alt, it zapped and i said eff this..... lol i stopped for the day after that
cherrington17 03-07-2009 11:40 AM
you just touched the + from the battery to the ground on teh outside of the alt... thats all.
sparks aren't much to worry about. (just scares the bejesus outta you for a second)
Nate's Alero 03-07-2009 11:43 AM
oh christ it did....... i was like WOAH FU*()*&(*&^(%!
Cliff8928 03-07-2009 01:11 PM
Originally Posted by GM
The intake pushrods are identified with yellow stripes and are 5 3/4 inches long.
Exhaust pushrods are identified with green stripes and are 6 inches long.
Tighten the bolts to 19 N·m (14 lb ft). Use a torque angle meter in order to tighten the bolts an additional 30 degrees.
That's the official specs. It also says to install all of the components back in their original location.
Nate's Alero 03-07-2009 01:42 PM
thanks! ill do that then
:) update tonight
alerored04 03-07-2009 04:09 PM
edits
Ghadsphi 03-07-2009 04:12 PM
^^^ might wanna change that to a pm. I might get really drunk like a tend to and want some foneloven at 5am
alerored04 03-07-2009 06:35 PM
Bring it on! I am friendly and too lazy to send a PM. This forum is so small and tight knit that I really dont need to worry about it.
cherrington17 03-07-2009 07:38 PM
RICK ROLL HIM!! :lol:
01OldsAleroGt 03-07-2009 07:46 PM
:emotlol: worth every second to do that... and make sure to get a voice recording just so we can all laugh our asses off
Nate's Alero 03-07-2009 08:46 PM
:LOL:
alerored04 03-07-2009 09:27 PM
Maybe I will take it down now. ahoes!
cherrington17 03-07-2009 09:50 PM
:lol:
oh... lighten up. (seriously.. i hope no-one did prank you)
