neg battery terminal?
I was just wondering now that i relocated the battery to the trunk can i just run the amp grounds from my system to the - terminal of the battery or will i get alt whine and other interference?
should easily be able to do that. And it shouldn't produce whine, its not producing a ground loop... it IS on the ground
ok i just wanted to check cause i know nothing about audio |
Only a bad ground should produce undesirable interference.
