-   -   ceiling lamp (http://www.aleromod.com/forums/showthread.php?t=27684)
silveralero88 06-23-2009 01:34 AM
ceiling lamp
My alero's ceiling lamp keep fallign down.. any advice ot keep it up?
99alerogirl 06-23-2009 01:37 AM
if you have a sunroof, pull down the headliner board at the back of the sunroof... hold the black piece down with one hand, and push up on the dome light with the other. you can try to use glue or something if you want, but that's how i got mine to stay up.
PappaSmurf 06-23-2009 01:58 AM
I used Viagra, and then I met ADRIA! ROTF
-Smurf
CactusWill 06-23-2009 04:05 AM
I used plastic zip ties, you can use one big one or connect 2 smaller ones. Bend down the small flat end of one and put it through one of the 2 metal holes in the roof so that when you feed it across to the other hole it pops right through the other side. Then pop the transparent plastic cover off the light assembly, and feed the 2 plastic zip tie ends through the insides of the assembly as you put it into place. Snap it all the way in and tighten the zip ties down good, and put the plastic cover back on when you're done. It might take a few minutes the first time around because its a little awkward and frustrating, but once you get it tight its not going anywhere.
