-   -   Break Light On??? (http://www.aleromod.com/forums/showthread.php?t=2793)
xsavyor1 07-01-2004 05:24 PM
I just changed my front and rear Break pads. And the anti lock light and the traction control light is on??? any Ideas?
Redog 07-01-2004 06:16 PM
ABS speed sensor (in the hub)
Low brake fluid?
BLK03GXS 07-01-2004 10:23 PM
Did u use metalic pads?
Mikebeast 06-23-2011 11:34 AM
I'm having the same problem....
Shiwnath 06-23-2011 12:20 PM
This thread is almost 7 years old....
lonnie 06-23-2011 12:47 PM
LMAO...is this the record for a thread revival....lol?
a.graham52 06-23-2011 12:52 PM
well it would help if somone had completed the thread with what ever fixed the concern...
slownlow43 06-23-2011 01:09 PM
At least they used the search button...
Is your SVS light on as well? I would start by checking the wheel hubs for play (put your car on jackstands, grab the wheel at 6 and 12, and see if you play by tugging back and forth)
a.graham52 06-23-2011 03:11 PM
yeah, check your brake fluid light. if the abs light was not on before doing your brakes thne maybe you accidently hit one of the sensors and damaged it?
